Old 08-04-2015, 07:39 AM   #1
beerrun's Avatar
Cleaning rubber floor in toy hauler
What is a good cleaning product to clean rubber floor in garage area of toy hauler?
beerrun is offline   Reply With Quote
Old 08-05-2015, 06:02 PM   #2
WolfWhistle's Avatar
Found this... should be about the same for our rubber floors. I don't want to use anything that leaves a film that could make it slippery. Or anything with a solvent and nothing abrasive. I do have some aluminum polish splatters that I need to get up. I'll try the solution with vinegar they recommend in the following link.
Care should be observed to not wet it too much that water gets into cracks at the walls.
How to Clean and Care for Rubber Flooring Tiles
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 08-05-2015, 06:39 PM   #3
beerrun's Avatar
Very good thanks
Old 08-06-2015, 07:51 AM   #4
Taranwanderer's Avatar
I'm confused...that article tells you not to use anything acidic, but then tells you to mix vinegar in hot water...last I checked, vinegar is acidic, yes? Not likely acidic enough to damage the floor, but Holy Contradiction, Batman!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 08-06-2015, 10:30 AM   #5
Plain water is acidic
Tap water that is
Old 08-06-2015, 10:46 AM   #6
PolarisGuy's Avatar
I personally have had great luck with a watered down version of Totally Awesome. I use the stuff on everything and it's only a buck at any Dollar General Store. Don't use it full power cause it can be too strong for stuff.
RV: 2016 Stealth WA2916 Toy Hauler
TV: 2005 F250 PSD
2012 Polaris Sportsman 850XP
2014 Brute Force 300 (daughters)
2016 Days Camped: 22
Check Us Out On YOUTUBE!!
PolarisGuy is offline   Reply With Quote
Old 08-06-2015, 11:18 AM   #7
Tap water that is
Yeah...but BARELY!
Old 08-06-2015, 11:37 AM   #8
They say awesome is citrus base and bad for gel coats and decals
Just so fine is offline   Reply With Quote
Old 08-06-2015, 02:18 PM   #9
What is this "cleaning" you speak of?
2014 XLR27HFS
2006 Ford F450 Dually Diesel
breezyhillfarm is offline   Reply With Quote
Old 08-06-2015, 02:40 PM   #10
Awesome found at dollar stores
toy hauler
