Old 03-19-2015, 01:12 PM   #11
Campingnut's Avatar
Some TT toy haulers are very bad for this when loaded with toys. A dually will not make a difference.
Tim and Bev
2013 Cedar Creek 34RLSA, Magnum 2800w inverter, 560w of solar.
2015 F-350
Campingnut is offline   Reply With Quote
Old 03-19-2015, 01:12 PM   #12
brer_rabbit10's Avatar
I think ependydad has the right answer. Go to a truck stop and get weighed and then find a way to redistribute the weight forward if your specs are off. It's a dangerous situation to be in.
Bill Case
Silverback 35QB4
F350 Diesel prime mover
brer_rabbit10 is offline   Reply With Quote
Old 03-19-2015, 01:17 PM   #13
I think he already knows he's light on the front, scales is just going to verify it.
Find some easy way of adding wt to the front if fw is not an option.
Old 03-19-2015, 01:21 PM   #14
Campingnut's Avatar
To add weight to the front of a friends toy hauler like this, his had a bed in the front, we put a fresh water tank under his bed and he added water to it when he needed the weight on the front.
Tim and Bev
2015 F-350
Old 03-19-2015, 01:26 PM   #15
Fulltime family RVer
The reason that I mentioned scales is that I think the scale will tell you how much weight needs to be shifted around. And, armed with numbers- I'd likely talk to Pro Ride or Hensley and see if their hitches can combat the problem.
For moving weight- we had a member who mounted a thick piece of steel to his TT tongue to combat similar sway issues. It's radical, but might help:
tongue WEIGHT
ependydad is online now   Reply With Quote
Old 03-19-2015, 01:30 PM   #16
Campingnut's Avatar
Yes in the end a Hensley/Pro pride was used to fix the problem completly on my friends.
Tim and Bev
2015 F-350
Old 03-19-2015, 01:35 PM   #17
tongue WEIGHT
He should know how much weight he needs as it doesn't sway with fw tank filled. BUT, knowing the exact wt could help. He can also get it at home with a set of bathroom scales.
No hitch made will combat a "too light" tongue wt.
Old 03-19-2015, 01:43 PM   #18
I think the OP mentioned that adding water reduced the sway, but it was still there. I've never pulled a big TT so I don't know what is to be expected.
You can get the tongue weight, but without knowing the overall weight- you only know a portion of what you need to know. You can't find the percentage without knowing the overall weight.
Reading more into avolnek's post about adding the steel, it ends with him switching to a Pro Ride.
Last post by avolnek
Old 03-19-2015, 02:35 PM   #19
caper's Avatar
What he is trying to say that a different hitch will not add weight to the tongue. The OP must find a way to increase the tongue weight. His idea of having the bike in the center of the trailer might also help. If he has the bike to one side it will cause the trailer to track differently. When he added water to his tank the sway was not as bad because the water did off set the weight difference a bit.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-19-2015, 02:49 PM   #20
Campingnut's Avatar
The hitch might not add weight but I will say this a Pro pride or Hensley will greatly effect how it tows. I am living proof and I will not tow another tt without one.
Tim and Bev
2015 F-350
bike, sway
