Originally Posted by Adh203
Mine has the same sticker BUT FR says that is how much weight the garage can handle not the cargo capacity you have to look for the yellow stickers on the inside front door or drivers side front of the trailer. Mine says only 1485# cargo capacity. It's 305v12
Check the GVWR. We are actually talking about two different ratings here. For total load you take the GVWR and subtract the dry weight of the trailer and that will show you the maximum that trailer should weigh. I have found however that most manuf have separately rated the garage area. So for example, many will have a max garage weight of 2500lb but when looking at the GVWR minus the Dry weight you might have 3700 lb for example of load capacity. This would mean with 2200 lbs of ATV's you would have room for another 1500lb's of everything else (water, pots, pans, etc etc) they just dont want all of that weight in the garage. The issue I run into is I also need a 2500lb garage but only want a dual axel trailer and that will often leave me with only 1000 lbs for the rest of the trailer. full tank of water on most of these is well over 800lbs so you can run out quickly.
