Old 05-12-2015, 06:01 PM   #11
Play Harder's Avatar
WW happy B🎉Day - NorthStar well I planned on getting this done about 3weeks ago - or should I say I started - you might have to camp out for the summer - for me to finish another 😎😎😮
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 05-12-2015, 06:06 PM   #12
NorthStar - it doesn't hurt to pull the pan and check how much friction plate material is sitting on magnets or other bad parts - also a good time to add bigger trans pan and new longer filter - also check for stuck bearing or wear - if you see wear around ball bearing holes - it's gonna burn up soon
2008 Can Am Spyder
Old 05-12-2015, 06:21 PM   #13
WolfWhistle's Avatar
The book says to change my 2500 tranny fluid at 25K miles
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 05-12-2015, 06:42 PM   #14
northstar1960's Avatar
2008 Can Am Spyder
Had a quick lube place blow up my tranny at 50,000 miles they put in a new one . it has a drain plug and i dump the fluid twice a yr . can only add a gallon at a time but helps keep it clean and now i have 3 tranny coolers on ,while towing it stays between 135 and 165 . 190 when pulling the long passes
northstar1960 is offline   Reply With Quote
Old 05-12-2015, 08:34 PM   #15
Thanks PH!
It looks like my oil temp runs 80 to 90 degrees over ambient while pulling.
Old 05-12-2015, 10:42 PM   #16
Yep the fastest way to blow a tranny is have it serviced and power flushed
Old 05-12-2015, 11:34 PM   #17
Left Coast
If you don't have the special tools for the OD clutch housing, don't take it apart..... it has opposing lip seals and a feeler gauge WILL NOT compress them. If clutches for OD aren't burnt, it'll be okay. The 3/4 clutch mod is the fix....and Transco makes a nice sk. Sprag updates also good, as are electronics.
Old 05-13-2015, 01:50 AM   #18
Everything is apart have press -- only thing I don't have is a washer so taking it to a local shop to have all parts jet cleaned $25 can't beat that -- yes replacing all electrics including harness
2008 Can Am Spyder
Old 05-13-2015, 07:38 AM   #19
Taranwanderer's Avatar
Ok, you're gonna have to explain this. Being a manual transmission guy for all my life, but considering going to an auto in my next truck (I may not have a choice,) so I need to hear why having your tranny serviced can make it "blow."
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 05-13-2015, 08:03 AM   #20
Mr. Dan's Avatar
.... (this is not easy w a quadrasteer)....
Play Harder, this statement prompts me to ask if you're a member of the forum on Denali Trucks . Some there could probably benefit from your expertise.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
towing
