Old 03-29-2016, 04:33 PM   #1
northstar1960's Avatar
dexter axles lippert components
ok got around to installing my new dexter EZflex equalizers . real simple job except when it came to the outer springs where FR decided to use lippert track alignment system , now the dexter wet bolts are not long enough to go through . Dexter was no help as their system only works with complete dexter axle hardware . called lippert and took mesurments of the wet bolt size needed with no luck they were either to long or to short
so ended up with the EZflex equalizer and wet bolts for the spring attachments by equalizer , but none now for the outer spring eyes . so now i'm searching for wet bolts that will work or will need to just install the dexter brass bushing with out being able to grease them
KIND-A-SUX's
northstar1960 is offline   Reply With Quote
Old 03-29-2016, 04:40 PM   #2
SilhouettePenny's Avatar
If this is what you are looking for, I got them at eTrailer.com
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2017 - 63
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
Old 03-29-2016, 06:00 PM   #3
Got 4 of those all ready came with the e-z flex kit , but with the mixing of parts on the axles using the lci correct track system the bolts are not long enough for end of the spring eyes where the correct track system is being used
Old 03-29-2016, 09:07 PM   #4
NS,
Just curious what this mod is getting you. Sorry for the lack of knowledge...
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 03-29-2016, 10:12 PM   #5
the flex equalizer are suppose to give a much smoother ride. best thing is to lookup the ez flex and see for yourself .
Old 03-30-2016, 09:35 AM   #6
chpence1's Avatar
Cool
2005 Dodge Ram Laramie, SRW
5.9L Cummins Turbo Diesel 24 valve
2013 Forest River Thunderbolt XLR 380 AMP
Cow Bell
2010 Star Motorcycle Stratoliner Deluxe
chpence1 is offline   Reply With Quote
axle
