Old 07-28-2015, 05:42 PM   #1
northstar1960's Avatar
domectic t-stat bad
the domectic t stat had been working great . run the air when put on cool and the heat when on furnace . here in west yellowstone it got to 37 last night put the t stat on furnace like normal and the air came on with the furnace . guess it's time for a replacement after only 3 months .what garbage but under warranty so will call FR and see about having them send me a new one . any better replacements out their others might have used ?
northstar1960 is offline   Reply With Quote
Old 07-28-2015, 05:57 PM   #2
oldgold's Avatar
Did the fan come on or the actual AC?
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
Old 07-28-2015, 05:58 PM   #3
guess it could also be the pc board set up the the ac unit . most likely that's it since it is what determines where to send the juice . seems when it on furnace it's sending power also to the ac unit when it should not . what a pain
Old 07-28-2015, 06:01 PM   #4
just the fan on the ac as the temp was set higher then the unit air temp . but the fan in the ac should not come on when t stat is set to furnace . just the furnace should come on not also the ac fan . it's been running fine until last night .
I'll bet the pc board is bad
Old 07-28-2015, 06:02 PM   #5
oldgold's Avatar
Probably right
Old 07-28-2015, 06:06 PM   #6
I may just end up running a separate t stat for the furnace by passing the ac unit pc board all together . not like i can just run to a dealer and wait weeks for them to fix it . maybe FR will send me the parts i need under warranty
Old 07-28-2015, 07:37 PM   #7
WolfWhistle's Avatar
Set your fan for auto... When on low or high the ac fan runs with the furnace.... It's a feature.
Amazing how you call it garbage but don't know how it works??
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 07-28-2015, 07:40 PM   #8
oldgold's Avatar
We do keep our fan running when it's cold while running the heat. Especially with a 15 month old. The constant background noise helps keep him from waking up. Plus, it keeps the warmer air even around the camper.
Old 07-28-2015, 10:18 PM   #9
Taranwanderer's Avatar
+1. You beat me to it, WW!
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 07-28-2015, 11:24 PM   #10
looks like the power failure caused it to reprogram it's self . once i got into the system initialization mode i was able to turn off the ac fan when the furnace is running . amazing how friendly people are around here , now i know why i stopped posting so much thanks for the reminder
