08-03-2015, 04:59 PM
#21
R3, with the 31fqsl frig being in the slide, I replaced the one noisy factory fan with two quiet computer fans. Much better performance. There are provisions for two on the mounting plate.
Thanks,
Jeff
-2016 XLR Nitro 31 FQSL
-2006 Chev Silverado 2500HD Duramax LBZ
08-03-2015, 05:09 PM
#22
Thanks for the info. Are they a standard connector?
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
08-03-2015, 05:18 PM
#23
No, I just soldered and heat shrinked. Also forgot to mention that mine had a large piece of paneling blocking the majority of the upper vent opening. I removed that when I installed the second fan to allow room for plenty of airflow. I think it was there in attempt to get moving air across the freezer coil but seemed to be futile.
Thanks,
Jeff
08-04-2015, 09:27 AM
#24
Does anyone have pictures where they installed the fans and what they wired them to?
08-05-2015, 05:17 PM
#25
Originally Posted by laurajean
Can anyone tell me if this is common for the dometic refrig. in my XLR?
Usually prefer to hook up electric and turn on the refrigerator before leaving to camp or fill the refrigerator. I finally turned it on when we got to camp. We were on electric but it took 24 hours to cool the refrigerator down and 12 hours for freezer. Is that common? I turned on the gas an had it on auto, no real difference. I am worried this needs repaired or replaced. I noticed the check light came on for a few minutes but I recycled it and it went out.
Wolf, how did yours act before it went out?
John
Hi L, you might want to add your model trailer and even tow vehicle so everyone can see at a glance what you own.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
08-05-2015, 07:22 PM
#26
WW,
How do you update the profile? I could not add anything as you suggested.
08-05-2015, 07:49 PM
#27
Georgia Rally Coordinator
Originally Posted by R3Jones
My previous trailer had a Norcold and it cooled very quickly. I could turn it on when loading the frige and it would get cold in a couple hours. My new trailer has the dometic and I too was wondering if something was wrong. Also the temperature adjustment (thermistor) is extremely touchy.
-R.Jones
Nitro 31FQSL
I too had the Norcold in previous campers and they seem to out perform the Dometic. To me it more China junk. And the sad part FR buys into these companies due to good prices on large buys. I would think its time to start sending e-mails to the Pres of the company and voice our concerns. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
08-06-2015, 06:04 AM
#28
Our reefer was marginal at best, took forever to cool down 115v, worked "ok" on gas. Hubby rigged 3 120mm fans at lower air inlet drawing air in and he repaired the factory vent routing. Now it cools down in a few hours and maintains 37* reefer and 5* freezer. My man's got to have his cold adult beverage! Can't really take pictures as there is nothing to see without dis-assembly, sorry
08-06-2015, 07:02 AM
#29
Can you tell me more detail, what had to be taken apart, what type of fans. Where did you purchase?
08-07-2015, 06:56 AM
#30
Fans are 12v dc 120mm computer fans from Amazon $9 ea. He popped off the lower vent and somehow rigged the fans, I think hot glue. Uses a toggle switch for on/off. He also modified the cabinet the reefer fits into to ensure air flow to the unit. Sorry I can't be of more help....
BTW, he used MY windshield sun blocker thing to fix the vent air flow issue....
08-07-2015, 08:35 AM
#31
Thanks...
05-07-2018, 09:34 PM
#32
I have a double door dom. Refrigerator. When on auto it blinks LP and will only work on LP. Any ideas? I am thinking a blown fuse.
05-15-2018, 07:21 AM
#33
When we purchased our the tech said to let it run all the time. When we stored it at our home I let it run all the time. And never had an issue. Now we store it and they only allow the battery charger to operate so I bring it home a couple of days before we leave and turn it on empty for 24 hours and that seems to work perfectly. Good luck.
2013 SP 240 Anniversary
Tundra CrewMax 5.7L in Pyrite Mica
Clark, Mary Jane & Max our German Short-haired Pointer
(2011-42)
05-15-2018, 08:44 AM
#34
Responding to post #26
click User CP near top... then look down the left margin for Settings & Options... then Signature... add what you want to look like... like what trailer, the year, what you tow with... anything your heart desires
WW
Hyper Lite was sold
05-23-2018, 06:25 PM
#35
The electric part of my domestic refrigerator doesn’t work. The 5 amp fuse was blown, which I replaced outside in the back of the camper where the gas and electric come together, but it still won’t cool on electric, it will cool only on gas. The display on the front of the frig says the electric is on, but will not cool.
