Old 04-27-2014, 07:27 AM   #1
Dometic thermostat control
Hey Guys, uncovered the 2014 27HFS yesterday so the wife could start putting all the stuff she bought over the winter in the camper, haha. I pulled the battery out over the winter to keep it charged and re-installed to give her light. I also plugged the power cord into a 110 outlet as to not run the battery down. When I did this the A/C turned on. I went inside and the Dometic control unit was blank, no visible read out on the display and no light indicating what mode it was in. I pressed some buttons and checked for a battery under the cover with no success. I ended up unplugging the cord until I have time to troubleshoot. We just bought the unit last fall and only used it twice so I do not have a lot of experience with it yet.
Can anyone give me some advice, Thanks in advance.
motts461 is offline   Reply With Quote
Old 04-27-2014, 08:07 AM   #2
fonzie's Avatar
I don't have a digital thermostat but here is manual in case you need it.
File Type: pdf Dometic Thermostat- Single Zone Digital.pdf (1.40 MB, 105 views)
Fonzie
Old 04-30-2014, 05:46 AM   #3
RFK
RFK's Avatar
I have the 2013 version but I think the thermostat is the same. I would start with the breaker / fuse panel under the fridge. When opening mine last weekend I found one breaker tripped Rather odd because nothing was plugged in over the winter. The only thing I did electrically was start the generator a few times but the reset of the breaker did the trick
Ray & Barb
2012 Sierra Duramax 2500HD 4 x 4
2013 Forest River XLR Hyperlite 27 HFS
2007 Harley Electra Glide Classic
RFK is offline   Reply With Quote
Old 04-30-2014, 05:48 AM   #4
RFK
RFK's Avatar
The breaker was for the water heater Again no reason I can find for that happening and it's working fine
Ray & Barb
Old 05-05-2014, 06:58 PM   #5
Checked fuses, breakers and tried to initialize from manual still the same. Made a call to dealer today and waiting on response.
dometic, thermostat
