Old 09-04-2012, 02:51 PM   #31
Originally Posted by f1100turbo View Post
It's all that lead ! Lol !
What lead?
bakken is offline   Reply With Quote
Old 09-04-2012, 03:14 PM   #32
lindy's Avatar
Your right HERK, my bad math I know 6x8lbs = 48 lbs, just had a brain fart I guess, and no IALWAYS take the rod out every fall as standard fall/winterization maintnenace.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 09-05-2012, 11:57 AM   #33
Mark and Linda's Avatar
Originally Posted by Mark and Linda View Post
Good instructions Lou...I replaced mine just after we bought the trailer used. I thought, boy this thing is all corroded, now I know. I pulled mine last week and drained my hw heater just to clean things out. And yes, you need to bleed the pressure on it..I forgot..good thing I had my shorts and flip flops on. I filled my tank back up and used the gas and ac to check it out...it did take awhile to get all the air out. Now ready to head out on Saturday morning....Oh...I used my adjustable wrench and a screwdriver to turn the wrench..still haven't bought a socket.
Well this morning I made a trip over to my local Lowes Store, about 4 miles. I found what I needed for only $5.67 using my Lowes Card I got a discount, total with tax $6.22. The best part is, it has a lifetime warranty on it.
Kobalt 1/2" Drive Shallow 6-Point Standard (SAE) Impact Socket
Item #: 337890 | Model #: 85314
So, it should withstand the pressure if I need to take my anode out.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
Mark and Linda is offline   Reply With Quote
Old 09-05-2012, 12:08 PM   #34
B47
You say it is a "impact Socket" - is it black or chrome? I hope you never have to use an impact wrench with that impact socket to remove your anode rod.
Not saying you can't use an impact socket with a standard racket, but if you need to use an impact wrench with it, you got bigger problems.
Old 09-05-2012, 12:34 PM   #35
It is an impact socket...cheaper than a regular socket. No, mine is hand tight I assure you. 30 years of working on aircraft...I know what torque is. I got the socket so I can use it with other things if needed, ...it was cheaper than the rest and won't break or round out off my anode.
Old 09-05-2012, 12:53 PM   #36
B47
Very good - sounds like you know what you are doing.
What was your aviation career about?
Old 09-05-2012, 01:25 PM   #37
I went to the Army Aviation School at Fort Rucker, Alabama on UH-1 Helicopters, flew in Vietnam with the 101st as a Crewchief on a UH-1H in 1971. Joined the Tennessee Air National Guard, 118th AW at Nashville in 1979. Worked on C-130A models, assistant crew chief, then we got a new C-130H2, I was the assistant on it in 1989. I was a crewchief for several years, then went back into the maint. hanger, where we did the phase inspections. Worked April 2009 to April 2010 on HH-60 Medivacs at Tennessee Army Guard.
Old 09-05-2012, 01:42 PM   #38
B47
Sounds like a honorable career. I am not too familar with all of the C-130 models, but when I was stationed at Dyess AFB, Tx in SAC, the Stewart AFB in Tennesee was closed and their unit and aircraft were transferred to Dyess. I remember seeing their guys polishing the radomes of what I was told were C-130A's (this was in 1961-62) with what I was also told was shoe polish. I remember those C130s had a smaller and different shaped radome than the later models. Truth or not - I don't know, but that is what I was told.
Also speaking of C-130s - we recently were at a RV park in Tucson, AZ, and it was close to the Davis Monthan AFB where retired/surplus military aircraft are stored. Driving along the base, you could see hundreds of various C-130s models sitting there. Kind of funny of seeing all of them there when you think that new C-130's are still rolling off the assembly line in Georgia.
Old 09-05-2012, 03:13 PM   #39
I live in Smyrna, home to the old Sewart AFB. The old hangers are still being used by civilian aviation and the Army Guard. The C130's with the funny nose were the old Roman Nose...we had one, a 1954 model that flew everywhere. We have a lot of people in the area that came to Sewart in the old days, worked here...and now retired.
Old 09-05-2012, 03:23 PM   #40
Dave Lyon's Avatar
Originally Posted by jmswms View Post
We also only do it at the end of the season-and yes you will get wet !
ditto - there is no need to drain other than winterizing.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
water heater
