Old 10-03-2014, 09:17 AM   #1
DSI switch on Water Heater
Can anyone tell me what his switch does?
mje000 is offline   Reply With Quote
Old 10-03-2014, 09:22 AM   #2
wmtire's Avatar
If it's "on" the water heater as you indicated, it's probably the electric heating element switch and not the DSI. The DSI/propane switch is usually located inside the RV.
If you have the Suburban brand water heater, this detailed FAQ may help, especially between the DSI/propane and electric heating element options (if equipped):
http://www.forestriverforums.com/for...ore-36197.html
The Atwood water heaters work the same, except the electric heating element switch (if equipped) will be located inside the RV along with the separate propane/DSI switch... and not on the face of the water heater like the Suburban can be.
If you don't have one of the two aforementioned water heaters, let us know what you do have, and we might can offer better guidance.
2011 Flagstaff 831 RLBSS
Old 10-04-2014, 03:10 PM   #3
WolfWhistle's Avatar
It is the switch for HWH 110 vac operation. I always switch mine off when not needed.
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
heater, water, water heater
