Old 06-08-2016, 04:23 PM   #11
northstar1960's Avatar
the 29 hsf has enough room for 4 batteries on the tongue. though i normally have one pulled out for use as a trolling motor battery when not fishing it's hooked up with the others .
northstar1960 is offline   Reply With Quote
Old 06-08-2016, 05:00 PM   #12
Dual batteries , I am trying to puzzle out what tandem batts would be ?
wanderingbob is offline   Reply With Quote
Old 06-11-2016, 04:32 PM   #13
Originally Posted by stevejd235 View Post
NYBigDog,
I'm plugged in 95% of the time when I camp. When I check the LED panel in the bathroom it indicates I'm full charged.
I will check the batteries when I get the camper this weekend before I plug in and report back. Most likely on Saturday...FYI
FYI....batteries were indicating 100% on the LED panel this morning after sitting in storage for ~3 weeks (under no useage...).
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 06-11-2016, 04:42 PM   #14
BandJCarm's Avatar
More juice, lasts longer. Stuff runs on 12V no matter how many batteries you have. 1, 2, 200, 1,000 whatever.
I have FOUR 6V batteries, which just makes 'em last longer than two 12's. Just connect 1 and 2 in series to make 12V and 3 and 4 in series to make 12V and connect the 1/2 to the 3/4 in Parallel as if it were just two 12V's.
Simple as mud.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 06-11-2016, 05:18 PM   #15
RETCHIEF's Avatar
Why would you want the positive off one and the negative off the other if they are wired in parallel? You can put the load cables on one of the batteries. Just curious.
Stu and Debbie
USAF CMSgt (RET)
2014 FR Super lite 27
2015 Ram Big Horn
RETCHIEF is offline   Reply With Quote
Old 06-11-2016, 05:27 PM   #16
A battery is defined as two or more CELLS , of approx 2 volts each . Those usually black boxes are just a container for those cells and the liquid . To get twelve volts you could use two " BATTERIES " of six volts or one "battery" of twelve volts or six individual cells .It ain't rocket science , you can stack em what ever fits . I need 24 volts on my boat and use three eight volts to spin my 6-71 Jimmy . I think " battery" goes back to the artillery , one was a cannon or gun , two or more was A " BATTERY "
Old 06-11-2016, 05:45 PM   #17
BandJCarm's Avatar
Or, a pitcher and a catcher................
FROG AR-0019-242
Old 06-11-2016, 06:18 PM   #18
clr
You take the TT positive off of one battery and the negative TT connection off of the other battery. This forces the current (power) to flow thru both batteries. Power like water will find the path of least Resistance and you want to keep both batteries in the loop at the same state.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 06-12-2016, 07:45 AM   #19
WolfWhistle's Avatar
I have 4, 230AH 6 volt batteries for a total if 460AH. I run each pair thru a battery selector / cut off. I charge via a magnum inverter / charger (2000w 100A) or 30A controller with 450W of PV panels (3 each). What makes it great is I have the magnum remote and the trimetric TM2030. First thing anyone boondocking will need; otherwise you are running blind
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
battery
