Old 03-18-2017, 03:51 PM   #21
A meter or test light would make this very easy. Start at the battery. Got light? Follow the red wire and check for voltage (light) at each junction. I'm sure you'll find it right away.
325BH is offline   Reply With Quote
Old 03-20-2017, 05:51 AM   #22
DouglasReid's Avatar
Originally Posted by Deano777 View Post
Cannot turn on house lights unless plugged in shore power.
When try and run on battery no lights in house including light in fridge.
Battery is good - was tested and hooked up correct.
All fuses are good.
Any ideas?
Battery disconnect Switch in OFF position
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 03-20-2017, 06:46 AM   #23
TURBS's Avatar
He said it's on [emoji15]
Old 03-20-2017, 09:20 AM   #24
This thread fixed my similar issue.
http://www.forestriverforums.com/for...ad.php?t=88534
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 03-20-2017, 11:34 AM   #25
beagle22b07's Avatar
Bad Disconnect
I had a similar problem on my MiniLite and it was a bad disconnect switch. If you wiggled it, things would work for a while, then stop again. Got a new switch and all is well now. Did you try jumping thru your disconnect?
Larry & Chris (Abbey & Brody camping cats)
2016 Ford F-150 XLT Sport, Super Cab, 3.5 EcoBoost, 3.55, 4x4, MaxTow w/36 gal fuel tank
2015 Rockwood MiniLite 2104S, EMS-30HW, Carchet TPMS
Days Camped: 2015 = 51; 2016 = 59; 2017 = 20; 2018 = 12; 2019 =
If you're lucky enough to be camping......You're lucky enough.
beagle22b07 is offline   Reply With Quote
Old 03-20-2017, 11:52 AM   #26
Sounds like if the reset button will not reset, you have a short circuit in the wiring or whatever is connected to it.
The 12v circuit breaker is doing it's job... keeping the wiring from burning up because of a short.
You;ll need to locate the source of the problem before you will be able to reset the 12v circuit breaker
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
electric, power
