Old 07-06-2015, 12:29 PM   #1
John513
JohnRiordan's Avatar
Electrical Fail
I was gone all day and came back to camper with no power. Checked all breakers including pedestal. Only one that was tripped was the AC. Checked power at pedestal and had power. Twist lock plug was hard to unplug from side of camper like it melted together. First thought was low voltage which will cause a more amp draw, but voltage was good. I pulled access panel inside to get to back of plug to remove. I cut romex off and pulled plug out and realized that the factory didn't tighten down the terminal screw on the common side. So it caused it to get hot and melt the plastic. These are things the factory should double check and owners to check periodically. It was so loose the wire didn't have any signs of being crimped down. This happened my second time out, so theres no way it loosened up in the short travels.
ID:	82194   Click image for larger version
JohnRiordan is offline   Reply With Quote
Old 07-06-2015, 02:30 PM   #2
First time out with our Wind Jammer I was under the bathroom sink trying to stop the water pump from banging and noticed the 110 wiring clamp wasnt tightened on the plug socket. Grabbed the wiring and it came out of the socket. After fixing that I checked all of the 110 plug ins and circuit breakers and found several that were loose or not installed properly.
Thos was on our first trip. So yes it is a good idea to check all of them.
Carrier is offline   Reply With Quote
Old 07-06-2015, 02:34 PM   #3
B and B's Avatar
One of the maintenance items I did was look at power connection and was glad I did pull the connector. I cut off and terminated the trailer wire correctly. Tightened all connections in the panel, many where loose.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 07-06-2015, 08:42 PM   #4
Is that something FR does or do they source it?
breezyhillfarm is offline   Reply With Quote
Old 07-06-2015, 09:03 PM   #5
B and B's Avatar
FR connects the AC inlet to the rats nest of wires in the unit prewire. They just do it quick with little regard to strip length or proper tightness of connections.
Old 07-07-2015, 05:55 AM   #6
WolfWhistle's Avatar
I need to check this... TODAY. JR, thanks for sharing. Thanks goodness for breakers and nothing more serious happened.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 07-08-2015, 04:01 PM   #7
XLR Production
This is an incorrect statement. We have weekly audits from our corporate inspectors and monthly audits from our vendors. We do try our hardest and take pride in what we do at our shop. The unfortunate thing about being a human is that we make mistakes. I am sorry for the issue that you have there and am thankful that nothing else more serious happened. Contact your selling dealer and we will take care of this.
bulletbob is offline   Reply With Quote
Old 07-08-2015, 05:06 PM   #8
Like Forrest Gump said: Stuff Happens.
Old 07-08-2015, 05:27 PM   #9
B and B's Avatar
For sure. Thank you Bullet Bob for responding and explaining the process.
Both forest river trailer I have owned had improper terminations AC input connections. I fixed both myself and did find what I stated. Looking at the OP connection it certainly looks like a loose or improperly terminated wire, there was heating and the plastic melted. I took delivery of a 2703 and the whole entrainment system disconnected when I tried to raise the TV. This is 2 hours after bringing it home. I traced all wiring out, trapped and fixed the rats nest. I do stand by my statement about care and dress of cables.
Old 07-08-2015, 06:12 PM   #10
As well as myself.
electric, electrical
