Old 06-22-2016, 10:57 AM   #21
Rhody's Avatar
Originally Posted by rockfordroo View Post
I believe you're just as bad as everyone else. You don't tell us what your 1/2 ton is rated for, even though you did say "All 1/2 tons are not created equal." How's the OP to determine how his might stack up if you don't tell him the specs on yours?
BINGO!!!
Rhody is offline   Reply With Quote
Old 06-22-2016, 11:35 AM   #22
Play Harder's Avatar
It's a secret 😅
Play Harder is offline   Reply With Quote
Old 06-22-2016, 11:43 AM   #23
Originally Posted by hawki8624 View Post
I probably should have mentioned I am looking at a 29hfs XLR with a rzr in the back.
If you ask on this forum, folks will tell you you need a 1 ton to pull a pop up and a Kenworth, etc for anything else.
Old 06-22-2016, 11:46 AM   #24
Rhody's Avatar
Boy O Boy is that the truth!
Old 06-22-2016, 12:38 PM   #25
mrpep's Avatar
Originally Posted by Play Harder View Post
I love these 1/2 ton debates did I mention I now have 329814 miles on my 2002 chev 1/2 ton pulling XLR HyperLight 29 hfs with a Can-Am Spyder in back fully loaded fuel cell and water tanks - and I camp almost every other weekend for over a year now - zero sway been up to 80 plus - I'm i slow going up steep grade yes - I mean mountain pass type of hills - could I keep 65 going up steep grade yes but don't like to the revs being that high so slow it down to 55 at a nice 3300 rpm
I remember when I first put a 10,5 lance camper on the truck with stock tires - thought we where gonna die driving it home --huge sway - barely do 40 around a corner - this was with air bags installed -- switch to Michelin E ply tires and all was good again - sway gone - no more truck roll -- ----
The weak link in my truck has been the transmission but everything else has not been rebuilt and currently 329814 miles and climbing - headed to Santa Cruz on the 1st from Seattle
Unfortunately You won't know what you truck can handle till you tow it - - I seen plenty of 3/4 ton trucks that have the same issue as 1/2 tons and rated less than some of the new 1/2 tons
All 1/2 tons are not created equal!
WDH Setup is critical
Bring on the 1ton critics lol
Get out and Play Harder
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015
2002 Chevy 1/2 ton Quadrasteer
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Do you use a trans cooler ? Or wdh?
mrpep is offline   Reply With Quote
Old 06-22-2016, 12:55 PM   #26
D_B Travelers's Avatar
...So...I shouldn't have bought the 2015 GMC Duramax 3500HD CC DRW for my Windjammer? Dang it...
D_B Travelers - 8 nights in 2017, 35 nights in 2016. 1st RV 2014 TT WJ3001w, new 2016 FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
D_B Travelers is offline   Reply With Quote
Old 06-22-2016, 12:58 PM   #27
mrpep's Avatar
2008 Can Am Spyder
Old 06-22-2016, 12:59 PM   #28
Enough truck?
Aftermarket big x2 stacked - transmission Cooler - about 3 times the size of the so called extra transmission cooler that GM provides w tow package (I did this after I bought and pulled the 29hfs - )
AmOil high temp transmission fluid
Transmission mods - big ones
Also dual electric fans
Aftermarket Air intake
Magna Flow exhaust
Anderson WDH
Old 06-22-2016, 01:04 PM   #29
Oldcoot
I'm saving your quote - that will live on forever on this forum 😅😅😅😅
Old 06-22-2016, 01:25 PM   #30
Should of bought a Mack, Peterbilt or bigger.
truck
