Old 06-22-2016, 05:41 PM   #31
davel1971's Avatar
Originally Posted by Play Harder View Post
Oldcoot
I'm saving your quote - that will live on forever on this forum 😅😅😅😅
It already does. He just copies and pastes it to every truck thread on here
David & Lynn
Old 06-22-2016, 05:54 PM   #32
Just stating what the weight police preach every time the subject is brought up.
Old 06-22-2016, 06:00 PM   #33
davel1971's Avatar
You have shown your numbers and your setup is good. The problem is when the vague question of "can I tow this with a 1/2 ton" comes up, it's almost impossible to answer. The tow ratings of 1/2 tons varies too much. From 5000 to 11,000 lbs. Payload varies greatly too.
David & Lynn
Old 06-22-2016, 06:01 PM   #34
hawki8624's Avatar
Thanks guys. I may go with a little lighter trailer. My tow rating is 9300 pounds due to having the 3.42 gears. The trailer I'm looking at is a sport trek 302vth by venture rv (kz) it is 6480 dry and gvwr of 8600
Sent from my SM-G935V using Tapatalk
hawki8624 is offline   Reply With Quote
Old 06-22-2016, 08:33 PM   #35
Play Harder's Avatar
I would still switch to E ply tires and add a transmission cooler
And you might want actually weigh any trailer your looking to buy before you drive it off the lot - I've noticed actual weight and sticker weight can be very different
Good luck
Play Harder is offline   Reply With Quote
Old 06-22-2016, 09:33 PM   #36
You still haven't discussed payload. What's the tongue weight of the venture and how much stuff (wife/kids/etc) are you putting in it?
Just askin'.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
Old 06-23-2016, 08:47 AM   #37
Aftermarket big x2 stacked - transmission Cooler - about 3 times the size of the so called extra transmission cooler that GM provides w tow package (I did this after I bought and pulled the 29hfs - )
AmOil high temp transmission fluid
Transmission mods - big ones
Also dual electric fans
Aftermarket Air intake
Magna Flow exhaust
Anderson WDH
So your vehicle is far from stock, but you're telling the OP he can pull the same as you with a stock vehicle??
2014 Chevy 2500 CC, Duramax
2017 Wolf Pack 25pack12 Toyhauler
polishdon is offline   Reply With Quote
Old 06-23-2016, 10:34 AM   #38
DaveSchwartz's Avatar
Should of bought a Mack, Peterbilt or bigger.
Enough truck?
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 06-23-2016, 10:54 AM   #39
Just askin'.
This is one of the most important numbers!
2015 Forest River EVO 2850
2012 Dodge Ram 2500 6.7 Cummins
Yamaha 2k x 2 with parallel cable
EMS 30 PI portable w/ Edison plug
Nights Camped (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 06-23-2016, 10:58 PM   #40
Polishdon For the record
If you read my first post -#6 post in this discussion - right after your post I stated what would need to be done to pull the 29hfs with a Chevy if he had a 4L60 transmission in his Chevy and other mods --if he has the 4L80 or above there would be no problems except towing up very steep grades - you just gonna be slow up steep inclines ---
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2002 Chevy 1/2 ton Quadrasteer
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
truck
