Old 06-25-2016, 07:34 AM   #51
Rhody's Avatar
Originally Posted by Mr. Dan View Post
Ha!
Better Lock Me Up Too!
Kayaks on the roof and 2 bikes in the back!!!
Rhody is offline   Reply With Quote
Old 06-25-2016, 12:46 PM   #52
I have a 2015 Silverado LTZ double cab with towing package. 5.4l, rated tow 9200lbs. I towed my XLR 29hfs with my Yamaha vstar 1300 and my wife's Suzuki Bergstrom 400 in the back from Atlanta, Ga to OKC and back through horrible thunderstorm. No problems. Rides and tows fine if you have the weight distribution hitch set up right.
bsquared is offline   Reply With Quote
Old 06-25-2016, 12:59 PM   #53
northstar1960's Avatar
well you're well over weight also , off to the weight police and into the poky with you . we can't have this kind of stuff getting around . it makes life tough for those of us that follow the weight rules . . on another note you really are over weight , and that 5.4 with the 29 in tow must be a real dog . just saying
northstar1960 is offline   Reply With Quote
Old 06-25-2016, 01:00 PM   #54
What is that little thing behind your truck ?
Old 06-25-2016, 01:06 PM   #55
Rhody's Avatar
Tacoma Power!
V6 Up a decent grade 60MPH 2200 RPM!!
Myth Busted!
Sorry Charlie Fords are for junkyards!
Old 06-25-2016, 01:11 PM   #56
Tacoma Power!
Myth Busted!
well no wonder you have a small tt you only have a tacoma . make sense now . so would that be a 1% grade ? just kidding here just so's you know
Old 06-25-2016, 01:16 PM   #57
Rhody's Avatar
Yes Yes All in good fun!
I like to Rib the Ford Guys!
All kidding aside that TT pulls really nice with the Tacoma...
I think the key is the Husky Centerline WDH system..
Just amazing how stable...
Prodigy P2 BC dialed in very smooth concise braking...
North Bound & Down Loaded Up & Camping!!
Old 06-25-2016, 01:32 PM   #58
a good wd helps all those in the know use the andersen . in yellowstone for the summer if you make it out this was give me a shout
Old 06-25-2016, 01:43 PM   #59
mrpep's Avatar
I opened a thread since I didn't want to jump this thread, I just didn't get many responses so will ask kindly about my concern. I tow easily with a wdh and trans cooler gauge shows low temps, engine temps low, no swaying - so all seems fine but today I weighed my tv and tt and found that I am maxing out just under 12k lbs and my specs state total gross towing capacity is 11k / 12k. Should I be concerned ? Or go with it?
mrpep is offline   Reply With Quote
Old 06-25-2016, 01:46 PM   #60
Rhody's Avatar
[QUOTE=mrpep;1238639]I opened a thread since I didn't want to jump this thread, I just didn't get many responses so will ask kindly about my concern. I tow easily with a wdh and trans cooler gauge shows low temps, engine temps low, no swaying - so all seems fine but today I weighed my tv and tt and found that I am maxing out just under 12k lbs and my specs state total gross towing capacity is 11k / 12k. Should I be concerned ? Or go with it?
Use The Force Luke!
truck
