Old 08-23-2014, 06:15 PM   #1
exterior light replacement
Sorry if this is a dumb question but I can't find anything in my manuals or on a search. The amber exterior light will not come on suddenly even though I have barely used it (by the door of my 24HFS). Is there some trick to removing the outer cover so I can check the light bulb and does anyone know what kind of bulb it uses? The other lights on the 3 switch panel work so I doubt it is a switch issue.
sponge is offline   Reply With Quote
Old 08-23-2014, 06:27 PM   #2
fonzie's Avatar
Usually you would use a small flat blade screwdriver and pry the lens off...see thread if similar lens
Outside oval orange light replacement
Fonzie
Old 08-23-2014, 08:54 PM   #3
WolfWhistle's Avatar
with a small blade straight screwdriver at the top of the lens, twist the blade which should allow prying the lens out. From memory I think it is a 1156 bulb. I am not near my 29hfs to look. I wonder if you have one of the mis-wired lights, where you have to have an inside light on before the outside light will work? It might be a long shot but worth checking.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 08-23-2014, 09:30 PM   #4
Thank you both. I will check out both suggestions. I really appreciate it!
exterior, light, replacement
