Originally Posted by wforst
We have just brought our new XLR Nitro 28TQDL home yesterday and have a couple of questions.
1. Where do you put the tank hose when not using it?
2. Should the furnace work if plugged into the home power?
Thanks in advance.
The best place for a tank hose (after thoroughly rinsed) would be in a storage tube mounted somewhere under the TT. Some people just throw it into the back of the pickup in a plastic tote with holes drilled so it will dry out.
The furnace runs on propane plus 12v (battery) power for ignition & blower fan. So, when plugged in, the battery will stay charged to run the furnace.
2014 Prime Time Sanibel 3250
