Old 07-23-2015, 09:01 AM   #1
Mainous's Avatar
Fan-tastic Vent question
Camping all week in Northern Michigan in the 31fqsl. From what I can tell, I have a model 5200 that (based on instructions) should power up at whatever speed it was running when powered off. However, it powers on at max speed each time. What am I doing wrong?
Thanks,
Jeff
Thanks,
Jeff
-2016 XLR Nitro 31 FQSL
-2006 Chev Silverado 2500HD Duramax LBZ
Mainous is offline   Reply With Quote
Old 07-23-2015, 12:31 PM   #2
Not sure what model FF's I have in my 29hfs but they come on at the speed I turned them off at. (I don't have the camper with me right now...)
I do have one that will turn on (but not open the lid...) when I plug the battery disconnect back in. Something I will have taken a look at during my schedule 60 day follow up.
Overall, my DW and I have loved the FF's...
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 07-23-2015, 08:07 PM   #3
WolfWhistle's Avatar
No help. I have different brand power vents
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 07-23-2015, 08:42 PM   #4
Timex's Avatar
Thanks,
Jeff
Is your model like one of these?
Fan-Tastic Vent's OEM 12 Volt Fans
Mine is a 1250. It has a knob that selects OFF/1/2/3 and a rocker type switch that controls out/off/in. If you turn the fan off with the in/out switch, it will come back on at whatever speed the fan was on when it was turned off.
If yours is different(I can't be of help).
If yours "should" operate as I described above, there may be a problem with a switch.
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 07-24-2015, 05:42 AM   #5
Mainous's Avatar
Thanks for the responses. The paperwork included with the coach show several models using the control panel as the identifier and based on that, I believe I have a 5200. The control panel is connected to the fan by an RJ45 connection. I'm guessing my control panel may have an issue. Will contact the manufacturer next week. At least it works.
Thanks,
Jeff
Old 07-25-2015, 08:57 AM   #6
R3Jones's Avatar
I found if you hit the blue power button to start, it will ramp up to max speed every time. If you hit the "up" button to start it will retain the settings if the last speed used. Click image for larger version
Name:	ImageUploadedByForest River Forums1437832643.351054.jpg
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
R3Jones is offline   Reply With Quote
Old 07-25-2015, 09:52 AM   #7
R3Jones's Avatar
Also, hitting the power button erases the speed memory.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
Old 07-25-2015, 03:18 PM   #8
Mainous's Avatar
Dude, u da man. Who'd a thought to turn it off with the down button and on with the up button rather than the power button at the top. Thanks for the input!
Thanks,
Jeff
Old 07-25-2015, 04:21 PM   #9
Timex's Avatar
Ya'll have those fancy, smancy Fantastic Fans!
fan, vent
