05-19-2014, 01:57 PM
First time camping.
Hi just hauled out xlr toy hauler first time and can't figure out the power. I got it hooked up to the camp power but fridge doesn't stay on lights don't turn on etc. wondering if there's a switch I'm missing. Thanks tom.
05-19-2014, 02:09 PM
Check if there is a breaker for your circuit at the campground's point of connection. It's usually right beside the outlet.
Don & Beverly, Chattanooga, TN
2011 Ram 1500 Quad Cab
2014 Rockwood Mini Lite 2304
2013 Rockwood Signature Ultra Lite 8310SS
05-19-2014, 02:29 PM
Ya I checked and there is power because fireplace and microwave work just no lights. The battery died in assuming is why no lights but shouldn't it continually charge ?
05-19-2014, 03:06 PM
The next thing to check is the 12 volt fuses. Open the panel on the converter and you should see them.
05-19-2014, 03:17 PM
Do any of the lights come on even for a second? If not, do you have a battery disconnect swtich?
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
05-19-2014, 03:26 PM
Yes all the lights come on but there dim. Also the fridge is on but as soon as I open the door it starts to make a clicking noise. The light flickers on and off and the check light goes back and forth. The disconnect switch is on and as soon as it's off have no lights period.
05-19-2014, 03:27 PM
First time camping.
Sorry... I just re-read the post and it's not just a fridge problem
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
05-19-2014, 03:32 PM
Have you check all the fuses?
05-19-2014, 03:39 PM
Sounds like it may be the converter. If you have a battery charger hook it up to your battery and if your light start working normal probably the converter. I had this problem on a travel trailer I had a couple of years ago and had to change out the converter.
Cajun Happy
2014 Columbus 365RL
2018 Silverado 2500 High Country
05-20-2014, 08:28 PM
Ok thanks for the help. Found the problem. It was 3 35 amp fuses tht were blown behind the converter. Just so y'all know if it happens to you.
05-20-2014, 09:04 PM
Don't know where to find the bypass switch and I did the de winterization. Where is the bypass usually located?
05-20-2014, 09:09 PM
I think you're answering in the wrong thread--think you meant to put this in your HW thread...
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
05-20-2014, 09:13 PM
We're the 3 fuses separate from the rest?
On the left of main fuse row?
TURBS
"Sabre owners united"
05-20-2014, 09:16 PM
The Battery bypass switch is usually located adjacent to your 12 volt Battery
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
05-20-2014, 10:08 PM
No on my unit it was behind those on the power distribution box. They were tucked up underneath hard to find hard to see
05-21-2014, 06:08 AM
Those fuses are for reverse battery protection.
They normally blow when the battery was hooked up wrong.
TURBS
