Old 08-29-2014, 02:33 PM   #1
Fresh water tank drain
I'm looking for the drain for my fresh water holding tank on my XLR. The hot and cold low point drains are obvious, but I have not seen an additional one for the fresh water tank.
pgstegall is offline   Reply With Quote
Old 08-29-2014, 04:24 PM   #2
What model do you have?
bigdog64 is offline   Reply With Quote
Old 08-29-2014, 04:27 PM   #3
I've got a 2014 340X12HP.
Old 08-29-2014, 04:27 PM   #4
markb5900's Avatar
I don't have an XLR but on my Salem, that drain is right behind the trailer tires.
You kind of have to look up from the side to see it.
Mine looks like the type of valve that is on the back of most toilets. Kind of oval shaped.
If you know where your fresh water tank is on the unit, look directly under that part and it will probably be there somewhere.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 08-29-2014, 05:35 PM   #5
I have a xlr 27hfs and my drain is in front of the forward axle,it is a blue line just like the low point drain for the water heater. Just remove the cap and it drains slowly. On yours I would expect that it is somewhere close to the fresh water fill point.
Old 08-29-2014, 05:42 PM   #6
Thanks Mark. It's sandwiched between the wheels. And there's only about 3 inches of tubing sticking out.
Old 08-29-2014, 05:43 PM   #7
markb5900's Avatar
That is how mine is also.
Glad you found it.
When you drain it, open up a faucet or two on the inside, seems to go faster to me.
Mark B
2017 GMC 3/4 Ton TV
drain, fresh water, tank, water, water tank
