Old 09-26-2016, 10:51 PM   #11
Taranwanderer's Avatar
FYI, the fridge and freezer did cool down to normal temp after a few hours running on gas. So the cooling mechanics, the condenser, the evaporator, are all working. The board is showing 120V at the two "prongs" that the element plugs in to. What if I just take the electric heating element out of the "sleeve" in the burner, switch it over to electric, and see if the element gets hot? If it doesn't, then I'm guessing that the element is toast. If the prongs are powered but the fridge isn't getting cold, it has to be a bad element, right?
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 09-26-2016, 11:11 PM   #12
Lost in time
Pull the leads and check the continuity of the element. If it's toast it will have no continuity at all.
SidecarFlip is offline   Reply With Quote
Old 09-27-2016, 08:41 AM   #13
Dazed & Confused
M&K Hoffman's Avatar
Here is a thread I wrote back in August about my experience with our fridge: My DM2652 Story. I have installed the fans and controller, but real world testing is probably not going to happen until next year.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 09-27-2016, 09:25 AM   #14
Originally Posted by Taranwanderer View Post
Thanks for the Ford AC video recommendation. This a Dometic DM2652, for the record.
So many questions, so little knowledge...
Taran, I'm not sure you read my suggestion correctly as you talk about "Ford AC". I am trying to point you in the direction of Ford's refrigerator service troubleshooting information on the net, for your Dometic fridge issue, so I will suggest one more time. Just sayin'
Old 09-27-2016, 09:33 AM   #15
Head Rambler
While that will work, it's much safer to take an ohm meter and check the continuity of the element. That's a 325 watt element, so it's going to get really hot in a hurry if it is good.
If you do decide to try that, make sure you're not touching the rod and it's not touching anything that could burn or melt.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-27-2016, 09:34 AM   #16
Head Rambler
Oh yeah, and don't get shocked!
Gotta go campin!
Old 09-27-2016, 10:17 AM   #17
clr
There is also a chance that the refrigerator is not level enough to operate. Make sure the unit is level with a ammonia absorption type refrigerator it has to be level to operate.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 09-27-2016, 01:39 PM   #18
DouglasReid's Avatar
X2,
It is a lot more reliable and much quicker than waiting to see if it cools overnight by hooking the element directly to an outside 120V source.
MUCH cheaper than going to some technician and paying him to do what you can do yourself!
Most times the element can be easily changed but you may have to disconnect yoru refrigerator and pull it into the camper to get access to the element.
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 09-27-2016, 02:29 PM   #19
If it's running on AC it will be plenty hot at the end of the heater where the wires are attached. You don't have to remove it. By the way , the thermistor attached inside on the fins in the refrigerator. Is the sensor for the board. It looks like a thin wire with a clip. Sliding it up the fin lowers the temp.
hillsdaletc is offline   Reply With Quote
Old 09-27-2016, 02:39 PM   #20
Dazed & Confused
Originally Posted by DouglasReid View Post
X2,
Well actually that idea came from a technical publication and is used to prove that the system works. If it does work your problem is most likely associated with the control board which will include the thermistor.
~Mike & Kim~
fridge
