Old 09-26-2016, 01:37 PM   #1
Taranwanderer's Avatar
Fridge just took a dump...
SO, I came home from OCMD last Sunday, plugged in after parking the rig. Unloaded clothes, bikes, gear, etc. Around Tuesday night last week, went out and unloaded the fridge, all was well. Then this past Saturday, I'm out there cleaning, vacuuming, etc--open the fridge to load some beers in, and everything is HOT. Fridge is totally shut off, freezer is totally defrosted. Threw everything out. Won't work on electric or propane. Why can't stuff work for more then 2 years these days?
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 09-26-2016, 01:45 PM   #2
If you do not smell or detect the presence of amonia you most likely have an electrical issue. Look to Ford refrigerator RV repair and troubleshooting videos on the net to get you familiar with what might be your problem. Just sayin'
Old 09-26-2016, 02:53 PM   #3
Battery good?
How about the status lamps on the front upper panel ... what do they show?
DC fuse? AC breaker?
WW
Old 09-26-2016, 04:05 PM   #4
Thanks for the Ford AC video recommendation. This a Dometic DM2652, for the record.
So, I went out and did some troubleshooting. All the lights on the front panel are working normally, as is the light inside the fridge. The fuses on the board in the control panel were both OK. The unit does ignite the burner when you set it to gas, which I didn't think it was doing. The board is getting 12V DC and 120V AC like its supposed to be. So if it cools down in the next few hours on gas only, it may be a burned out 120V element. But if that's the case, why didn't the gas burner come on when it was set to "Auto" when the temp inside rose to abnormal levels? Or is the burner prevented from igniting when 120V AC is turned on, regardless of temperature? Does the board even "know" what the temp level is inside? How does it know when to turn the AC element or the LP burner on and off?
So many questions, so little knowledge...
Old 09-26-2016, 04:39 PM   #5
Flybob's Avatar
If you haven't used it on propane for a while or have changed the tanks, there could be air in the line that needs to be bled out.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-26-2016, 05:30 PM   #6
Dazed & Confused
M&K Hoffman's Avatar
Well if you would have asked people to guess what fridge you had, as one of the many unfortunate owners of that particular unit,that would have been my guess.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 09-26-2016, 05:47 PM   #7
Head Rambler
Unfortunately, the board doesn't know when the element is burned out, and it doesn't use the temp to determine if it should switch energy sources. If there's 120 available at the board then it switches to electric power.
Gotta go campin!
Old 09-26-2016, 06:12 PM   #8
Dazed & Confused
You can check the electric element by disconnecting it from the circuit board and hooking it up directly to 120 vac. Let run overnight. If your fridge gets cold, the element is OK. Mine was at 32 degrees in the fridge compartment after 12 hours.
~Mike & Kim~
Old 09-26-2016, 06:22 PM   #9
120Vac determines which mode its in. Exactly right, BR.
Someone (dealer, T), needs to figure out the problem... board? Element? zombie apocalypse?
WW
Old 09-26-2016, 06:23 PM   #10
Never thought of that MKH.
WW
fridge
