Old 03-13-2015, 03:59 PM   #1
Fuel station
Xlr 2011 fuel station has never worked had it look at with no luck.i have checked all the power i have lights on the gauges 1 tank reads full i did put fuel in them both 1 runs the generator the other to the pump. I can not get the pump to come on. There is a transformer in the wiring has anyone had it repaced?
toyhauler2011 is offline   Reply With Quote
Old 03-13-2015, 04:04 PM   #2
TURBS's Avatar
Pump is 12v ?
Old 03-13-2015, 04:05 PM   #3
TURBS's Avatar
Is there power to pump?
Old 03-13-2015, 04:06 PM   #4
I am pretty sure all the power going back there is 12 volt
Old 03-13-2015, 04:14 PM   #5
Not sure will have to pull wiring out of pump housing
Old 03-13-2015, 04:18 PM   #6
TURBS's Avatar
That's where I'd start
Old 03-13-2015, 04:19 PM   #7
TURBS's Avatar
Not real sure what the transformer is all about tho ?
Old 03-13-2015, 04:19 PM   #8
Thank you
Old 03-13-2015, 04:29 PM   #9
My 2015 29 hfs has rocker switch near hose and another safety switch near stove. Turn on safety switch then rock once for on twice for off.
lonb is offline   Reply With Quote
Old 03-13-2015, 04:40 PM   #10
I have done that on my 2011 i have a fuel pump swith on the wall panel and then one on the pumping station press it once and the fuel gauges register that they have fuel and the gauge lights work but no pump
Old 03-13-2015, 05:35 PM   #11
Rookie19's Avatar
Fuel station
My shockwave has a 15min timer rocker switch I have to click on the "control panel" inside the trailer and then it has a on/off /safety switch outside the trailer by the fuel pump box.
When I click the switch on the control panel a light lights up.
Might need to start tracing wires. First thing I would check is the wiring behind the control panel and fuses.
Tow rig - 2006 F350 with some goodies
Trailer - 2014 T27FQDX
Toys - 2005 yfz450 with some goodies, 2005 rhino 660
Rookie19 is offline   Reply With Quote
Old 04-20-2015, 08:28 PM   #12
There is an older thread on here about fuel station problems that today, I was so happy to have seen! My fuel station has been non-working for over a year, but I read on here about the gears being swelled up and binding. I told my technician about it today when I got him to work on it, and he lightly sanded down the edges of the gear impellers. In short order, my pump is now working like a champ. Thanks to all here in the forums! Probable saved me beaucup dinero for a replacement pump!
I Roo The Day is offline   Reply With Quote
