Old 07-19-2015, 08:12 AM   #1
Fuel Station Fuse Size
My fuel pump and gauge quit working. I haven't checked the fuse yet but when looking at the converter panel it has a 15A fuse yet the hand-written label from the factory says 20A. I don't want to put a 20A in unless I know that's right. Does anyone know the correct fuse size?
Thanks!
DennisTD is offline   Reply With Quote
Old 07-19-2015, 08:55 AM   #2
Homebrew's Avatar
Thanks!
My XLR has a switch on the main control panel to turn on the power for the pump station.
I forget to turn the switch on every time I need the pump.
I will check my fuse panel later today and reply back.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 07-19-2015, 08:59 AM   #3
Thanks. Yes, my interior switch is on and the pump used to work. I appreciate the help!
Old 07-19-2015, 09:10 AM   #4
Homebrew's Avatar
Looks like my XLR is label 20amp and has a 20 amp fuse see picture Click image for larger version
Name:	ImageUploadedByForest River Forums1437315004.416215.jpg
2014 Ram 3500 DRW
Old 07-19-2015, 09:13 AM   #5
Thank you! Mine is labeled the same way but with a 15A installed. I'm sure I'll find it blown. Thank you so much for the help!
Old 07-19-2015, 11:18 AM   #6
My fuse was good although I changed it to a 20. Now gotta figure out why the pump AND fuel gauge both quit working!
Old 07-19-2015, 11:55 AM   #7
I think I was told during our PDI that the fuel pump was also on a timer and would stop working. I don't remember how long they said it was. You might try turning everything off for a little and retry it.
hdmtnrider is offline   Reply With Quote
Old 07-19-2015, 04:55 PM   #8
I think when you turn on power on inside tt the switch activates a 15 min timer as I recall.
Bones is offline   Reply With Quote
Old 07-20-2015, 06:16 AM   #9
WolfWhistle's Avatar
You should have a light on the panel indicating a blown fuse (when one is blown)
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
WolfWhistle is online now   Reply With Quote
Old 07-21-2015, 06:40 AM   #10
Fuse was good for sure, no pump or fuel gauge workee. All switches on. Will troubleshoot or take to dealer after Sturgis. Not really concerned about the pump for now, but would like to know how much gas I have in the tank as I have an onboard gen. Oh well. Still beats the hell out of sleeping in my tent like the last six times at Sturgis.
fuse
