Old 12-29-2013, 11:09 AM   #1
Fuel station not working on 27HFS
Help! For some reason, even with the switch turn in next to the fridge, my fuel pump is not working. The gage doesn't go up (may be low on gas though), but the pump will not dispense fuel.
Is this a known problem? Could the pump have failed? Anything else I can check?
jwhitemx15 is offline   Reply With Quote
Old 12-29-2013, 11:53 AM   #2
John McClain's Avatar
Does the pump turn on ?
check on the frame rail next to hose box there is a off on switch there to
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
Old 12-29-2013, 01:42 PM   #3
It doesn't seem like the pump is turning on at all.
Old 12-29-2013, 03:26 PM   #4
1. check the fuse if its good than !
2. check the switch is there power to and from the switch ? if yes
3. check is there power to the secondary switch on the frame rail ? if yes
4.pull inspection plate off pump. if there is of build up like varnish or crap from the tank, spray it out with carburetor cleaner and reassemble.
Old 12-29-2013, 08:27 PM   #5
Thanks for the quick reply!
I have checked the fuse underneath the toy hauler behind the fuel gauge and it looks fine. Is there another fuse somewhere?
I couldn't find another switch in the frame. Where exactly is this located? Front of the trailer? Back of the trailer?
Old 01-05-2014, 12:30 AM   #6
RFK
RFK's Avatar
Inside the gas cap door is a rocker / momentary switch. One tap turns on the pump and gas gauge , two taps turn them off With both not working and a good fuse it may be the switch too
Good luck
Ray & Barb
2012 Sierra Duramax 2500HD 4 x 4
2013 Forest River XLR Hyperlite 27 HFS
2007 Harley Electra Glide Classic
RFK is offline   Reply With Quote
Old 02-04-2014, 10:36 PM   #7
I had problems with the switch at the pump not turning the system off. Wonder what the rationale was to have a switch inside as well as outside? Could they figure gasoline is so valuable they needed three security systems (1) Inside switch (2) Locked gas station door (3) switch at fuel station.
BG
BGG
Camarillo, CA
bikepsych is offline   Reply With Quote
Old 02-06-2014, 12:38 PM   #8
(Its for safety). I love having a out side or switch or (safety switch). I had the handle valve stick on me once and I was able to kill the pump right away without having to go back inside. I also don't like to let the pump run for 15 minutes waiting for the timer to shut the pump off, it seams hard on the pump to me. You can just leave the frame switch in the on position too. I also like not having to walk back inside to turn the pump off .
Old 02-07-2014, 07:50 AM   #9
dhatfield6's Avatar
Send a message via Skype™ to dhatfield6
I had the same problem with my new 2013 XLR. Just another of the many problems from the factory! Poor, very poor quality control in my opinion. Wired incorrectly!
Doug & Kim
2013 Forest River Thunderbolt XLR 380 AMP, 2013 Ford SD F-450 DRW 4WD CC 172" King Ranch
2012 H-D FLHTK Electra Glide Ultra Limited, 2004 H-D FXSTDSE2 Screamin Eagle Deuce
[FONT=Arial]Trips in 2013-(4) Nights Camped-(56) Trips in 2014-(5), Nights Camped-(60)
Trips in 2015-(4) Nights Camped-(44) Trips in 2016-(2) Nights Camped-(17)
dhatfield6 is offline   Reply With Quote
Old 04-07-2014, 05:50 AM   #10
WolfWhistle's Avatar
jwhitemx15, what did you find... if the solution was found? I am close to delivery of a 29hfs and I want to learn all I can from you guys and gals. Thanks, Wolf.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
