Old 05-01-2012, 06:21 AM   #1
Fuel station question
Is there some sort of water separator for the fuel
Station on the 27hfs? I think I want a fuel station, but I am concerned about getting water in it.
Also, do you guys keep yours full all the time, or am I okay only filling it up halfway?
Any help on this would be great! Thanks...,
Dom
Toy Haulin is offline   Reply With Quote
Old 07-04-2012, 11:33 AM   #2
Depends on what you haul. As for axle weight. Be carfull, 2000 in the cargo bay plus fuel you have already over loaded the small axles.
betme1959 is offline   Reply With Quote
Old 07-09-2012, 03:58 PM   #3
Don't even think about 2000 lbs in the garage. The load capacity of the entire trailer is listed at 1650 lbs and with the actual weight of the trailer, there is only 1350 lbs of cargo capacity to stay within the gvwr. With only 1000 lbs in the garage, the 2 3500 lb axles are overloaded by 360 lbs. Actual Cat scale axle weight... 7360.
Rotech is offline   Reply With Quote
