Old 07-24-2014, 10:16 AM   #1
fuel tank
I have a 2013 Nitro xlr that is suppose to have a 30 gal fuel tank for pump station and fuel supply for the Gen set.The problem is it only accepts 16 gal on fill up and produces 16 gal on pump out....I took the outside dimensions, did the math, and it should hold 30 gal. Where do I go from here?
daddavis is offline   Reply With Quote
Old 07-24-2014, 10:29 AM   #2
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Did the gauge show empty or did you run out of fuel and then filled the tank? A faulty fuel gauge would make sense to me.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 07-24-2014, 10:46 AM   #3
Ran out twice filled up twice. Fuel gauge read correct full and empty both times.
Old 07-24-2014, 11:08 AM   #4
You measured the tank and it seems like everything checks out. What if the tank is plumbed incorrectly and the generator draws fuel only from the top half, or is there something inside that tank taking up space. Another possibility is that the fill cap does not vent properly and you get vacuum buildup inside the tank.
Just guesswork.
Edit: Could you have a double wall tank, that would explain what's going on.
Old 07-24-2014, 11:15 AM   #5
TURBS's Avatar
Just guesswork.
I vote for double wall tank.
"sabre owners united!"
turbs
Old 07-24-2014, 11:16 AM   #6
Yep I will see if I can dip the tank to see if there may still be fuel in it. You might be rite stuff may be only using top half of tank. Thanks for the ideas, I will be back on here to let you know what I find.
Old 07-24-2014, 11:19 AM   #7
Almost looks like it, could use a clean wooden dowel or the like and check how much is left when it runs dry, or maybe try to get some inside dimensions.
But please don't use the matchstick method
Edit: Oops, I'm slow at typing. Meant to add to turbs' post.
Old 08-06-2014, 09:35 AM   #8
Chrism28's Avatar
Did you find anything out on your fuel tank
2014 xlr nitro 24fqsl
Chrism28 is offline   Reply With Quote
Old 08-06-2014, 11:07 AM   #9
Thanks for asking
Here's the latest. Tried to dip the tank but filler neck is funky with to many corners. Did the sonar thing (tap on side of tank), sounds empty. The wife and I are heading to the salt flats this Friday for speed week so will fineness the filling process and see if it is an air bubble cutting me off early at the gas pump. Hopefully I'll figure something out. I will post the results.
Old 08-06-2014, 11:31 AM   #10
Chrism28's Avatar
My old toy hauler I had to reroute the breather tube cause it would fill with gas and make it burp out at you
tank
