Old 04-01-2015, 08:27 PM   #1
Furnace Upgrades
Bullet Bob,
Looking for verification if possible. I have been told that the furnaces in the XLR HyperLite are from Suburban Manufacturing. When I check their website it seems that SF Series matches closest to what is installed. If this is true, is it possible to get a larger BTU model in the same series line?
Just curious if you have any input on this. Thank you for your time...
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 04-01-2015, 08:30 PM   #2
Originally Posted by stevejd235 View Post
Bullet Bob,
If you do get a larger BTU model, you better check on getting much bigger propane tanks. Furnaces don't sip propane, they chug a lug it.
Old 04-01-2015, 08:35 PM   #3
OldCoot,
Will keep this in mind. It may just be better to look into installing a Wave unit like WW did...
Old 04-01-2015, 08:49 PM   #4
Ceramic heaters are cheaper but you need a generator or shore power.
breezyhillfarm is offline   Reply With Quote
Old 04-01-2015, 09:02 PM   #5
breezyhillfarm,
Luckily, I will have either shore power or my generator with me if I go with a Wave. But always good to call these items...
Old 04-01-2015, 09:59 PM   #6
Play Harder's Avatar
Actually if you have a furnace that's heats your space properly it will use less propane than a furnace too small that has to run 24/7 that can't get the temperature needed -- - there really isn't that much difference in price from a 20btu to 35btu and the main concern would be the amps it draws - not really the propane usage-
I am very interested in this topic, and I would like to talk to somebody at FR to discuss off forum - - but been crazy busy this week at work to follow thru -- going camping this weekend and will have a 24/7 opinion on Monday -
Play Harder is offline   Reply With Quote
Old 04-02-2015, 06:28 AM   #7
Play Harder,
I'm in a similar boat that it's hard to make phone calls during the day with my job. I will let you know what my dealer comes back with on this topic.
Old 04-02-2015, 06:45 AM   #8
XLR Production
Bullet Bob,
What model unit do you have
bulletbob is offline   Reply With Quote
Old 04-02-2015, 07:07 AM   #9
BB,
It will be the 29HFS. I have it on order and I'm told hit should be completed by the end of April.
Thank you for your time on this...
Old 04-02-2015, 02:23 PM   #10
XLR Production
The SF20 furnace used in this model, is the only size that will fit in the space allotted.
Old 04-02-2015, 02:50 PM   #11
BB,
Thank you for confirming what options I have. Rather know I don't have an option than not knowing.
Have a great afternoon...
Old 04-02-2015, 06:19 PM   #12
WolfWhistle's Avatar
breezyhillfarm,
The Wave 6 (or 8) uses propane and not much of it, also no fan to draw down the batt-rees. Only issue is oxygen and it not being vented. Either get a low oxy sensor / alarm or make sure you crack a window open. It runs at the same pressure as the range, not on the little bottles like Heater Buddy does. I have one of these for a little greenhouse and bought an adapter hose to run on 20#ers.
See the flexible elbow lower right on the unit. I T'd off the range line. Make sure if anyone gets one to get the cover, they don't like dust and can get fouled.
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 04-02-2015, 06:27 PM   #13
Hello! that's what I thought... good to know. What if a clever guy built a box forward of the rear side door; in the garage and mounted another SF20, ducted into the garage and maybe into the bathroom? This isn't for me, because I have the Wave heater.
Hyper Lite was sold
upgrade, furnace
