Old 07-09-2016, 05:13 PM   #1
Furnace question
Newbie to rv's. Is the a/c unit supposed to run when the furnace kicks on? Is the a/c used for circulation or what? Btw, my rig is a 2015 thunderbolt 425
Sent from my SAMSUNG-SM-G870A using Tapatalk
duallyd is offline   Reply With Quote
Old 07-09-2016, 05:18 PM   #2
Craigban157's Avatar
On mine you have to have the thermostat set to auto (AU), if not the furnace and AC will run at the same time.
2015 Salem261 BHXL
2016 GMC Sierra 2500HD
2015 nights camped 90
2016 nights camped so far 120
Craigban157 is offline   Reply With Quote
Old 07-09-2016, 05:40 PM   #3
Head Rambler
That's a common question lately.
As Craig said, on the newer thermostats the A/C fan runs anytime the furnace runs if you have it in anything except Auto. Set the fan mode to Auto and it won't run when the furnace runs.
Gotta go campin!
Old 07-09-2016, 05:41 PM   #4
Mr. Dan's Avatar
... and the way to do this is to cycle through modes until you get to FAN and then use + or - to move FAN off of HI or LO and onto AU (auto).
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 0; booked = 28
Old 07-09-2016, 05:51 PM   #5
MR. Dan, you are correct, I should have given a little more information to duallyd.
2015 Salem261 BHXL
Old 07-09-2016, 06:07 PM   #6
Awesome, thanks. I knew it wasn't rocket science lol. Works like it should now!
Old 07-09-2016, 06:17 PM   #7
Great, it took me one whole season to work all the bugs out of mine with a lot of help from this form.
2015 Salem261 BHXL
Old 07-11-2016, 01:32 AM   #8
Have another question. Have 2 black tanks, does the one black tank flush connection do both tanks? I have 2 separate pull valves, but can only find the one connection for a hose. Don't use the second toilet as much, but don't wanna drain it, if not needed, or overfill it if I'm flushing the main black tank.
I do have 2 of the LED tank/battery read outs, one in the front, and one in the garage.
Thanks for the help!
Old 07-11-2016, 12:04 PM   #9
Head Rambler
I believe you should have three holding tanks. One gray water tank and two black water tanks. They all hook to the same outlet connector, but each will have it's own valve. If you don't use the half bath you can elect not to dump it each time.
I think the lavatory in the half bath dumps into that black tank as well, so you need to keep an eye on it if it gets used.
Gotta go campin!
Old 07-11-2016, 02:46 PM   #10
Well, I have 1 fresh, 2 gray, and 2 black. When I topped off the main black tank with the hose, the second black tank level didn't change. Of course, the main LED level checker, only shows one black tank, but the rear one also shows a black tank.
furnace
