Old 08-26-2016, 03:55 PM   #1
FYI Ceiling Vents Comming Un-tapped
Every ceiling vent that I could push on and would raise the ceiling up had the metal sealing tape from duct to ceiling torn or came loose from ceiling under the vent housing. I have to assume that the ceiling was moving as I was traveling causing tape to come loose or tear. One I re-tapped and the other two, I put foam around the vent opening cutting off any hot air from
mixing with the cold. My 15k unit works good, but has hard time keeping up with heat load. Usually I have to run both A/C's in the summer but only have 30 amp at house.
2014 XLR Viper 305V14
2017 Ram 3500 LB DRW
phuber9458 is offline   Reply With Quote
vent
