Old 10-30-2014, 10:00 PM   #1
Steve38's Avatar
Garage LED lights
Was too dark in the garage with the bed raised up.
In stalled LED strip lights.
ID:	65614   Click image for larger version
Steve38 is offline   Reply With Quote
Old 10-30-2014, 10:14 PM   #2
Shinny's Avatar
Nice and bright
2015 Sierra 32QBBS-23 nights camped since the end of June 2014
2015-sorry to say only 11 nights so far, more to come though
Shinny is offline   Reply With Quote
Old 10-31-2014, 08:57 AM   #3
Sunseeker 2500TS
Where did you wire it in?
rocrider50 is offline   Reply With Quote
Old 10-31-2014, 09:00 PM   #4
Taranwanderer's Avatar
I felt the same way--too dark with the bed up, it blocked all the light from the overhead lights. I applied 4 stick-on adhesive lights under the bed frame. LED, batteries will last a long time, no wiring required.
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20 (‘18)21 (‘19)23
2019 Honda CRV (camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
Old 11-03-2014, 08:51 PM   #5
We had the same problem in our 395 and installed some LEDs also but ran them the other way left to right. It makes a lot of difference. Click image for larger version
Name:	ImageUploadedByForest River Forums1415065872.199537.jpg
the.wilsons is offline   Reply With Quote
Old 11-03-2014, 08:58 PM   #6
mud yapster's Avatar
Great idea thanks I'm going to check on this and wire some into a switch. Thanks for the idea.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 11-03-2014, 09:12 PM   #7
Not trying to hijack the thread but I tapped into a hot wire up by the motor for the bed lift. Then just wired in a small rocker switch mounted on the wall next to the entry door.
Old 11-03-2014, 09:26 PM   #8
Thanks I was going to check for a hot up there also, glad to hear there is one up there by the motor. Thanks again for the info.
Old 11-05-2014, 10:10 PM   #9
Where did you get the lights, size, cost? We have same problem. Great idea.
XLR 24 HFS
Bpenn is offline   Reply With Quote
Old 11-05-2014, 10:33 PM   #10
I ordered our from Amazon. Don't remember for sure but they were around $15 for 16 ft. I had bought several rooms for different projects in the camper. Put some behind the slide out molding and some in the pantry. Still want to do some on a motion sensor with the light under the steps to the front of the camper.
Old 11-06-2014, 10:40 AM   #11
Sunseeker 2500TS
Never thought about battery powered LED's. Works great when not on shore power and you don't want to drain the battery. Just need to find some that works on a remote and we'll be all set. Batteries should last awhile.
Old 11-08-2014, 05:21 AM   #12
Steve38's Avatar
I wired to the wall switch.
led, light
