Old 08-24-2016, 10:28 PM   #1
Garage wall construction? Want to hang a cabinet.
Curious if anyone knows how the garage walls are constructed? I want to add a small cabinet in the garage area of our new 420Amp. I am guessing they have aluminum wall studs, but am unsure of the spacing and width of the studs. If anyone has any knowledge of this, please advise!
REPO is offline   Reply With Quote
Old 08-25-2016, 06:48 AM   #2
R3Jones's Avatar
If you're talking about interior garage wall then typically they are wood stud framed but the spacing isn't consistent from one unit to the next. I would recommend using a stud finder.
If you are talking about an exterior or side wall it is more difficult to locate the aluminum framing. I've noticed in the mornings (after running ac all night) the studs are visible from the outside. If you look closely you'll see condensation forms on the outside everywhere but the aluminum framing. In the right conditions it'll be visually obvious as to there location.
Good luck!
-R.Jones
Nitro 31FQSL
R3Jones is offline   Reply With Quote
Old 08-25-2016, 09:19 AM   #3
Very interested in this as well; especially bolts/screws to use and things to avoid such as wiring and plumbing that might be in the walls.
2016 Ram 3500HD 6.7L CTD 4x4 CCSB
2017 CC 34RL2 Hathaway Edition
Andersen Ultimate 5th Wheel Hitch
florabama is offline   Reply With Quote
Old 08-25-2016, 09:27 AM   #4
JCCarr's Avatar
Some rental centers now rent infrared cameras to check for air leaks in your house. If you turn the A/C way up if it's hot out, or turn the heat way up if it's cold out, you can "see" inside the wall with an infrared camera as the room will change before the interior of the wall.
Rig: '16 XLR Hyper-Lite 29 HFS > 2014 Nissan Titan Pro4X 5.6L
Toys:
'08 HD Screaming Nemo Ultra > '07 HD Dyna Street Dori
Family: DH - JC, DW - Malinda, DD - Sparky the Wonder Chug (Chihuahua & Pug)
_____________
_______________________________________
Days Camped: 2016 - 22 (+13 reserved); 2015 - 27; 2014 - 16
JCCarr is offline   Reply With Quote
Old 08-25-2016, 01:17 PM   #5
ccsvolsfan's Avatar
I have a high quality stud finder that has a deep mode. It can see the metal studs. Also I always use the tap and listen method to double check.
ccsvolsfan is offline   Reply With Quote
Old 08-25-2016, 01:37 PM   #6
AquaMan's Avatar
Look at the outside wall on a dewy morning, you'll see every stud and cross brace. Then you can measure and transfer to the interior. Done this many times.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 08-25-2016, 09:11 PM   #7
Thanks for all the replies.
Just to confirm, I want to hang inside the garage on an exterior wall.
Old 08-25-2016, 09:58 PM   #8
How do you like your 420 AMP?
Is it the Thunderbolt 420 AMP? I've been looking at that one and am planning to trade our current camper to get one.
Is it everything you hoped it would be?
Stryker_242 is offline   Reply With Quote
Old 08-26-2016, 03:39 PM   #9
Well we just got it a couple weeks ago, so i can't really say. I love the deck, as I'm a morning coffee guy. Nice to sit out there and look at the lake!
Old 08-26-2016, 03:42 PM   #10
Yeah, the deck is what drew me to it and what sold my wife on it. She loves the way it opens up the kitchen/living room area with expanded space to move around. (She hates tight spaces...)
We haven't purchased one, but I haven't seen anything I like better than the Thunderbolt XLR 420 AMP.
Hopefully, I'll get to join your "Owner's Club" one day!
