Old 09-24-2015, 11:56 AM   #1
Gas Tank Inlet Poor Design
Anyone notice the poor design to the tank inlets that causes gas to sit in the inlet right at the cap? Anyone change those out with a better angled one that doesn't make it spill onto the side of the RV ?
Bro
Bro
Jaybro130 is offline   Reply With Quote
Old 09-24-2015, 12:00 PM   #2
clr
Yep had the same problem with my boat had to change the angle of the pipe into the tank to get the gas to flow better. Might help if you state the make and model and type of RV you are having a problem with.
clr is offline   Reply With Quote
Old 09-24-2015, 01:15 PM   #3
Yeah it's an XLR thunderbolt 300x12hp. Don't know if I can change the angle on it or not
Bro
Bro
Old 09-25-2015, 03:51 PM   #4
i just picked up my 27 HFS over labor day weekend and last weekend was my first time attempting to put gas in it on my way to a Mx track...lets just say it didnt go so well at the pump and im for the moment just taking a 5 gallon gas can and dumping that into the gas tank for now
MotoCrazy808 is offline   Reply With Quote
Old 09-25-2015, 08:05 PM   #5
WolfWhistle's Avatar
MC808, was it because how far forward you had to get the rig... Or are you ready to talk about it yet...
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 09-26-2015, 10:09 PM   #6
I have a 2015 24FQSL LXR Nitro and I tried to put about 5 gallons back in my fuel station so I could run my fuel pump once in a while and I too had gas pouring all out and down the side of my RV. The inlet hose like you said is too low going to the tank. Only good thing is that I will probley not use my fuel station until such time I'm able to add a generator.
hdmtnrider is offline   Reply With Quote
Old 09-27-2015, 05:54 AM   #7
I had trouble filling my 15 29hfs the first time. Tried rotating the nozzle until tank took the gas. Ended up being upside down was the answer. I use my fueling station all the time. I buy Ethanol free down the street and use it for lawnmower and other things around the house
2015 29 hfs / 06 gmc 2500hd
lonb is offline   Reply With Quote
Old 09-27-2015, 06:25 AM   #8
oldgold's Avatar
X2. I started pumping with the dispenser upside down as well. Works way better most of the time. Also keeping the spout about halfway down the inlet.
2015 XLR Nitro 30FQSL
2015 F250 King Ranch
oldgold is offline   Reply With Quote
gas, tank
