Old 07-09-2016, 12:18 PM   #11
Code 15, under frequency. Governer not able to maintain engine speed. Typical cause: to high of a current draw.. Reduce load, and retry.
Taking it to the shop is a good idea.
BBQGUY is offline   Reply With Quote
Old 07-11-2016, 08:57 AM   #12
NCCoachMan's Avatar
My brand new unit had generator issues this past week too - sounds like similar symptoms. How do you see the error codes??
NCCoachMan is offline   Reply With Quote
Old 07-11-2016, 09:15 AM   #13
AquaMan's Avatar
The start switch inside the generator panel will blink your error codes. The manual will tell you how to read/recall and the meaning of the codes.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 07-30-2016, 11:58 AM   #14
The genny problem was nad needle valve in carb.So I picked it up on Thursday headed out to a cook off.
Generator ran 2 a/c with no problems in 100 degree Texas heat .........Until about 9 PM last night the transfer switch keeps kicking in and out so it's back to the shop on Monday.
Tow rig: 2014 Ram 3500 CC
Old TH: 2007 376srv wildwood sport
New TH: 2014 340X12HP
rfregia is offline   Reply With Quote
generator
« 29 HFS | Table »
