Old 07-04-2016, 09:43 AM   #1
Generator problems again
I have a 5500 Onan Cummins in my XLR it has 500 hr. It will not hold a load rpms just go up and down even without a load. I has been serviced according to the manual just had the fuel pump replaced and still the same. Any ideas?
rfregia is offline   Reply With Quote
Old 07-04-2016, 03:49 PM   #2
R3Jones's Avatar
Are you getting any error or fault codes? Did you replace fuel filter?
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
R3Jones is offline   Reply With Quote
Old 07-04-2016, 03:51 PM   #3
-R.Jones
Nitro 31FQSL
Yes sir fuel filter was replaced with pump. Error is 36.
Old 07-04-2016, 04:10 PM   #4
R3Jones's Avatar
I've had error code 36 twice. The first time I was low on gas. The second time my fuel filter was clogged.
If you've recently replaced the fuel pump and are sure your full on fuel I'd focus on the fuel lines. The fuel line is usually strapped to the outside of the i beam. It might be pinched. If everything looks good you might want to replace the fuel filter.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
Old 07-04-2016, 07:15 PM   #5
dwhit's Avatar
Location: Chicago, Rochester now GA/SC at Lake Hartwell
Sounds like my problem which was fuel pump. Was it actually replaced? Hook it up to 12vdc and see if it pumps enough to fill a jar in 15 seconds.
I replaced pump myself...started immediately and ran beautifully. I didn't replace filter.
17 year old 5500 w/700 hours.
Your units' fuel tank at least 1/2 full?
XLR 415AMP, F350 Lariat 6.7 DRW, three bikes, NRA Benefactors.
Traveling 7 months/year
dwhit is offline   Reply With Quote
Old 07-04-2016, 07:23 PM   #6
It also sounds as if the carburetor has gum and garnish, entirely possible at those hours and repair history. Get some good fuel system cleaner and see if that corrects the problem.
Uberluber is offline   Reply With Quote
Old 07-04-2016, 07:30 PM   #7
dwhit's Avatar
I ran a 50% solution of Sea Foam thru mine...helped a little...smoked a lot.
Old 07-04-2016, 09:59 PM   #8
Mainous's Avatar
Do you hear a ticking sound when this happens? This would be the fuel pump cavitating and running dry. On my 31fqsl, I've found that the Onan pump on its own is not getting the job done. Primarily because of the long run of rubber hose to the tank at the other end of the RV. I intend to install a small lift pump to keep the line pressurized and assist the on board pump.
Jeff
Thanks,
Jeff
-2016 XLR Nitro 31 FQSL
-2006 Chev Silverado 2500HD Duramax LBZ
Mainous is offline   Reply With Quote
Old 07-04-2016, 10:29 PM   #9
Code 36. Generator stopped without a command from the switch.
Usually related to fuel or the lack there of.
Also spark plugs, clogged air filter, clogged fuel filter, bad fuel pump. depends on the age, but at one time there was a fuel filter on the carburetor and one on the pump. The one on the carb was been eliminated.
A dirty/gummed up carburetor is also a cause. They are not rebuildable; must replace with new.
There is s YouTube video showing how to try and clean it with SeaFoam.
BBQGUY is online now   Reply With Quote
Old 07-09-2016, 11:04 AM   #10
Thanks everyone. A little up date new fuel pump and filter a full service including spark plugs. Same result now it's giving a code 15. I have it scheduled for the shop me t week I will update once it is fixed.
Tow rig: 2014 Ram 3500 CC
Old TH: 2007 376srv wildwood sport
New TH: 2014 340X12HP
generator
« 29 HFS | Table »
