Old 06-14-2016, 04:17 PM   #11
How often will you be running the AC? If the answer is most of the time then get the bigger unit. If the answer is maybe once every 5 trips, or less, then get the 2 2000's.
I have a different brand but hooking up the 2 2000's takes time, one more thing to setup and take down every trip, and I dont need AC that often.
That being said, I bought a 3100 watt unit with remote start and love it! I was worried about the gas usage but not that big a deal. And you can run it on econ when you are not needing the AC. I also trip the 120v breaker for the fridge so it just stays on Propane.
Steve
Golden CO
2016 Grey Wolf 26RR Limited
92 GMC K2500 454
2006 Honda Rubicon ATV
zuterbru is offline   Reply With Quote
Old 06-14-2016, 04:33 PM   #12
I currently have 2-2000's and they work fine for the 13.5K AC and the micro at the same time. I also have the extended Berg tank. I believe that Berg tank is 5gal. I bought these because I can move them around easier that lifting the larger units. I did borrow a Yamaha 3000 to test and it was really quiet and smooth. It was just too heavy to lift for us.
bshort is offline   Reply With Quote
Old 06-14-2016, 04:45 PM   #13
I am in same boat. 2 Honda 2000 vs Yamaha 30iseb. Haven't made up my mind yet for my 29hfs.
ricky836 is offline   Reply With Quote
Old 06-14-2016, 04:59 PM   #14
NMWildcat's Avatar
We bought 2 eu2000i almost 10 years ago. Never have a lack of power for whatever we need. We also utilize a 6 gallon auxillary feeder tank so you never have to worry about adding fuel to a hot generator.
The 3000 won't be able to run as much simultaneously but does have the advantage of remote start/stop if you buy the model with that option.
We would buy the 2 2000s again in a heart beat.
Old 06-14-2016, 05:22 PM   #15
dcheatwood's Avatar
3000 will run AC and lights, etc. Heavier to load in TV alone than 2 2000s. In winter, cooler weather, one 2000 will probably be all you need. Fuel consumption in two 2000s versus one 3000 and noise level is something to consider. Either way you've picked a great brand of gen.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
generator
