Old 03-25-2016, 06:40 PM   #1
Chrism28's Avatar
Generators
What is the lowest watts you can go with for the hyper lite 30 hds
Chrism28 is offline   Reply With Quote
Old 03-25-2016, 06:50 PM   #2
Pickin' & Campin'
What all are you wanting to run?
Most folks size their generators to the amount of things they plan to operate.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 03-25-2016, 07:00 PM   #3
Chrism28's Avatar
Just the essentials ac once in a wile microwave little air comp
Old 03-25-2016, 07:47 PM   #4
WolfWhistle's Avatar
With 1 AC - 4000w IMO
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 03-25-2016, 08:08 PM   #5
Blackhat6mike's Avatar
My 15,000 BTU AC runs fine on a 3500 Champion gen. Microwave is no issue [1200 watt]
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 03-25-2016, 08:13 PM   #6
W5CI's Avatar
3000 watt minimum
Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 3
W5CI is offline   Reply With Quote
Old 03-25-2016, 08:54 PM   #7
TURBS's Avatar
Dometic recommends minimum 2500 watt genie .
This may help you.
normal appliance amp draws
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 03-25-2016, 10:32 PM   #8
Play Harder's Avatar
A Honda 2000 will run everything but not AC and microwave together and you will need a capacitor kit or booster kit for AC for start up - I don't recommend if your planning on heavy AC use but occasionally not a problem - I ran my AC for many years on a Honda 2000 no issues -
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2002 Chevy 1/2 ton Quadrasteer
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 03-25-2016, 11:38 PM   #9
Wire Wrat's Avatar
Our Yamaha 3000is will run the air conditioner, but will not run anything else when the AC is on. Our AC will start the fan then the compressor in separate sequences. That eases start loads. We did not encounter any problems running hair dryer, 1500 watt heater, or microwave. You do have to realize what the capacity of your generator is and use the appliances within the load range of the generator.
Be ware of the things you say and do for little eyes are watching you. Believe it or not, YOU are a role model
Wire Wrat is offline   Reply With Quote
