Old 05-24-2015, 05:46 PM   #11
mud yapster's Avatar
The pump is a 12 volt pump so you could have low voltage issue to pump. That would cause the low pump rate. Mine pumps about 10 gallons in 5 minutes. I thought mine was a little slow but yours is really slow. Also my pump is external mounted.check your battery voltage and make sure you battery is charged up good. My bed in the garage wouldn't go up with 12.4 volts so I fired up the generator and up it went.LOL
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 05-24-2015, 07:35 PM   #12
northstar1960's Avatar
Originally Posted by mike.t View Post
What is the fuel pump for? mechanical? Electric?
toy hauler comes with a fuel station carries 30 gallons . could only get 20 in . fuel pump is external and is only pumping about 1 gallon per 2 mins . my guess is a kinked hose in the tank to the pump or a clogged screen or some other stupid thing caused by people who put these units together and don't give a crap . I get good pressure but as soon as you hit the handle the pressure bleeds off and it the gas just trickles out
northstar1960 is offline   Reply With Quote
Old 05-24-2015, 07:41 PM   #13
not the battery or voltage . the unit pressurizes up and get good pressure but as soon as you hit the handle to put fuel in whatever the pressure bleeds off and i just get a trickle . guessing a kinked hose in the tank or clogged screen if there is one . if i got 2.5 gpm I'd be happy.I'm sure it's just more poor workmanship . now i can spend an evening after work to fix what shouldn't be broke
Old 05-24-2015, 07:44 PM   #14
Well i guess you can remove the fuel pump and get the make and part # off of it. Google your find and get the specs. If it says it is a 1.5 gal per minute get a bigger one. If it says it is a 4/5/6 gpm it's no good.
Happy motoring.
Guess it's not the pump but the typical FR poor workmanship . it's a fuel pump not a water pump . can't find one for this type of use that's only 1.5 gpm . besides it's all under warranty if it's not a simple fix then FR can fix it
Old 05-25-2015, 07:10 AM   #15
Fuel pumps on toy haulers are notoriously bad. When mine acted like yours it was usually the vanes swelling. You can open it up and trim them back. A mechanic told me they make them for diesel and when used in gasoline the plastic vanes have problems.
rzrnaz is offline   Reply With Quote
Old 05-25-2015, 10:44 AM   #16
I'll have the chance to get into in the next couple days . if it ever stops raining . not going to modify anything just make sure nothing is kinked or clogged . if all is good then i'll go the warranty route and get a new pump. I'll post what i find
Old 05-28-2015, 01:25 PM   #17
Subscribed. Mine is very slow too. 2016 29hfs
Red900 is offline   Reply With Quote
Old 05-28-2015, 03:45 PM   #18
2007 WildCat 32QBBS
05CrewDually's Avatar
Is there an inline filter? A partial clogged filter can allow pressure to build but lose flow.
05CrewDually is offline   Reply With Quote
Old 05-28-2015, 05:03 PM   #19
then you also have issues with your pump. I've operated many a fuel pump and they should not be as slow as I'm experiencing. still have not had a chance to get into it yet . been raining everyday here in west yellowstone
Old 05-28-2015, 05:08 PM   #20
have not had a chance to look into it yet . but yes a clogged screen , filter , kinked hose etc . since the pressure builds my guess in one of those is the issue . I'm leaning toward a kinked hose . maybe tomorrow eve i'll have a chance to give it a once over .I'll report my findings for others
pump
