Old 05-28-2015, 05:36 PM   #21
mike.t's Avatar
Toy Hauler Fuel Station Not Working | RV Supply Co.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-28-2015, 05:45 PM   #22
2007 WildCat 32QBBS
05CrewDually's Avatar
Originally Posted by mike.t View Post
If that's the case I would contact the manufacturer of the pump and ask if they offer replacement metal gears (most likely bronze).
05CrewDually is offline   Reply With Quote
Old 05-28-2015, 05:57 PM   #23
northstar1960's Avatar
If that's what is causing the problem then it's a warranty issue . having been like this since i used it for the first time just a couple weeks ago and the 29hsf was just picked up brand new april 8th . so just over a month . i'll see if it's something else if not i'll have forest river buy me a new pump
northstar1960 is offline   Reply With Quote
Old 05-30-2015, 07:10 PM   #24
Ok got under the 29 and checked the lines . the pick up line from pump to tank was kinked , the hose for one is way to long and they just shoved it in kinking the line. once I pulled it through and removed the kink it pumps IMO good not great but good about 5 gpm which is a lot better then the .25gmp . the hose it's self is cheap and soft and about 12" to long . when i get the time i will replace the hose with a better quality hose of the correct length
Old 05-30-2015, 07:16 PM   #25
mike.t's Avatar
Glad ya got it figures out.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-30-2015, 09:36 PM   #26
mike.t's Avatar
Read your reply again and noticed you said "got under the 29" I've been under my 32' many times.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 06-01-2015, 06:05 PM   #27
two days after purchasing i spent almost 4 full days under it . thought i got everything, guess i missed the fuel hose. A few minor bugs to go and it should be ok for awhile
Old 06-01-2015, 08:56 PM   #28
WolfWhistle's Avatar
I was under mine the best part of 5 days... wrapping pipes, tieing up wire... running wire... insulating... sealing holes... and a day just drawing a plan of where everything is for future reference.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 06-01-2015, 09:25 PM   #29
mud yapster's Avatar
Ok just this weekend mine slowed to a trickle when I noticed the hose was kinking off right at the pump handle. LOL I lifted the hose to straighten it out and good to go again. LOL cold beer time.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 06-02-2015, 07:08 PM   #30
new heavy duty hoses are i order all the way around
pump
