Old 05-21-2015, 09:50 PM   #1
northstar1960's Avatar
getting moreflow from fuel pump
So whats the deal with the fuel pump ? can only get about a gallon per 2.5 mins . checked for kinks but found none , pressurizes up good but then just pumps real slow . is there a flow control on the pump or other trick to getting fuel out . maybe a clogged screen if there is one
northstar1960 is offline   Reply With Quote
Old 05-23-2015, 09:44 AM   #2
haven't had a chance to get into thew pump yet .any suggestions ?
Old 05-23-2015, 05:21 PM   #3
WolfWhistle's Avatar
No help from WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 05-24-2015, 09:57 AM   #4
Thanks WW . guess i'll look into it . should expect more flow then a gallon every 2 or 3 mins
Old 05-24-2015, 11:44 AM   #5
mike.t's Avatar
What is the fuel pump for? mechanical? Electric?
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 05-24-2015, 11:53 AM   #6
Ford Idaho's Avatar
Toy hauler with a fuel station they are electric pump.
Not sure if they are submerged.
Old 05-24-2015, 12:04 PM   #7
mike.t's Avatar
They? Two? What kind of trailer? After market pumps put out about 9 GPM.Lets hope they are not submerged.
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 05-24-2015, 05:06 PM   #8
There could be some garbage in the tank that is blocking the fuel flow !
Is there a petcock or on - off manual valve on the tank ? It can be blocked .
Could be a hiden filter ?
cj06 is offline   Reply With Quote
Old 05-24-2015, 05:17 PM   #9
Ford Idaho's Avatar
"They" used generically.
Refers to pumps used in general in TH's that have a fuel station option.
Old 05-24-2015, 05:39 PM   #10
mike.t's Avatar
Well i guess you can remove the fuel pump and get the make and part # off of it. Google your find and get the specs. If it says it is a 1.5 gal per minute get a bigger one. If it says it is a 4/5/6 gpm it's no good.
Happy motoring.
2015 Salem 27RKSS
55' Chevy Bel-Air
pump
