Old 03-05-2015, 06:40 PM   #31
WolfWhistle's Avatar
Originally Posted by Play Harder View Post
Good to know - can't believe the heater won't keep up - - guess I'll be getting extra heaters - I know there is a lot of space to heat but you would think they would put s big enough heater in ---- coming from a lance all weather camper that would cooked you --- looks like - I will be wrapping pipes w heater coils and insulation --- thanks for input - better to know what needed before Hand - then to find out in the cold while camping
Get out and Play Harder😛
2015 XLR Hyper Lite 29hsf - loaded on order
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
PLay Harder, BTW I recommend for consideration the catalytic LP heater (shown in some photos) the popular sizes are 6K BTU and 8K. I put one beside the fridge directing towards the recliner; but the garage would need one as well. The are much more efficient... something in the order of 90% or better. And, costs less to operate and no furnace cycling. If you were to use the furnace constantly, two 20 lbs. cylinders aren't enough, IMHO.
If I were to insulate the floor again, I wouldn't take the days to cut and fit around everything, instead I would have insulated the top side of the coroplast belly pan but seal it with some kind of foam, as well as all gaps and seams. This can get wet, so consider what you use for insulation.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 03-05-2015, 07:48 PM   #32
northstar1960's Avatar
wolfwhistle . sorry i saw OH and thought couches . I did email them again today wanting solid answers . one thing i was told is the belly is sealed and heated . but now i find it's not , just sealed . the dealers no matter who are so full of it . they say what ever with out any knowledge of wtf is really in the units their selling or anything else for that matter . before the deal closed i was getting calls at least every other day . now i can't get them on the phone . just like in the other thread where they told him there was 5200 lbs axles . they really don't give a hoot if someone overloads a unit and they have blow out and do damage or die . their covered by saying it was over loaded .
What i don't understand is if you just had one bike in the back why did you have issues with axles bottoming out ? I told the dealer today that i expect to be able to carry 2 motorcycles up 1800 ++lbs and expect the unit to handle this plus the remainder of weight used up in other areas . very aggravating
northstar1960 is offline   Reply With Quote
Old 03-05-2015, 08:15 PM   #33
No problem.
Old 03-06-2015, 08:33 AM   #34
Play Harder's Avatar
Extreme weather package is not sounding very extreme -- hopefully it helps keep the heat in and less sweating w dual pane glass - I expected garage area to need a heater - anybody install bigger furnace? - add 2 heaters to my trailer equipment list -
On the other end of the spectrum dare to ask how is the AC unit I upgraded to he 15btu?
2008 Can Am Spyder
Play Harder is offline   Reply With Quote
Old 03-06-2015, 08:43 AM   #35
Stevejd235 hope u don't mind me hijacking your thread a bit ---getting some great information from members -- thanks starting this thread
2008 Can Am Spyder
Old 03-06-2015, 09:54 AM   #36
2008 Can Am Spyder
Play Harder,
Love seeing the other questions and comments. It's helping all of us...:thumbup:
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 03-06-2015, 10:32 AM   #37
2008 Can Am Spyder
The double pane does stop the condensation 99% and greatly helps.
Because of their inefficiency I would not consider a larger furnace, even if it would fit but I don't think it will.
I've only toyed with the idea of upgrading to a 15K but thought of making it a heat pump. But, I am not convinced that 15K would be enough by itself. I have also considered staying with the 13.5K and adding an 11K non-ducted in the garage. This might be too many BTUs. I would think at this point, it would require going 50 Amp. This isn't a problem since we have access and a compartment directly behind the utility "center".
Old 03-07-2015, 07:57 PM   #38
Getting ready to purchase 29HFS
Picked up Anderson WD hitch today defiantly like the size and weight --- along w there ultimate trailer gear come in a nice bag - that everything actual fits back in the bag - reviews coming in couple weeks
Name:	ImageUploadedByForest River Forums1425779711.532936.jpg
ID:	70944Click image for larger version
Name:	ImageUploadedByForest River Forums1425779737.441034.jpg
ID:	70945Click image for larger version
Name:	ImageUploadedByForest River Forums1425779750.571390.jpg
ID:	70946Click image for larger version
Name:	ImageUploadedByForest River Forums1425779762.794504.jpg
2008 Can Am Spyder
Old 03-08-2015, 09:34 AM   #39
Attachment 70944Attachment 70945Attachment 70946Attachment 70947
Get out and Play Harder��
2008 Can Am Spyder
That just pees me off that you have this and I don't! I am trying to figure out why you were defiant?
Can you share the part number and where you got the WDH? Thanks, Wolf
Old 03-08-2015, 10:18 AM   #40
Part # for Anderson WD hitch w 4"drop 6" frame 2-5/16 ball is part # 3350 -- they also make w 8" drop if you have a tall sitting truck part# 3380.
The ultimate trailer gear part # is 3600 - really a nice set includes 4 jack pads, 1 clean step, trailer levelers w tuff chocks, 2 extra tuff chocks, rapid jack and bag - rapid jack muliple uses looks like a time saver - allow you to use is to change a flat tire w no jacks needed..... All stored neatly in a handy bag - I like organized chaos 😎Click image for larger version
Name:	ImageUploadedByForest River Forums1425827872.673500.jpg
ID:	70966Click image for larger version
Name:	ImageUploadedByForest River Forums1425827889.672488.jpg
I purchased from my local trailer dealer down the street
2008 Can Am Spyder
