Old 07-22-2015, 07:12 PM   #11
2014 XLR 27HFS
Originally Posted by InTheSticks View Post
Dave961, I see you left the "RED" tab on yours...I thought your suppose to remove that after installation is done, no?
Yes, pic was taken immediately after install while I was still covered in dirt.
They do say to remove the red tag to make sure when you close it will close all the way.
Dave & Audrey
dave961 is offline   Reply With Quote
Old 07-23-2015, 11:40 AM   #12
How hard are those remote valves to install? I've done basic home plumbing with PVC and even copper. I've also done some irrigation work.
'15 XLR 27HFS
'15 Nissan NVP 3500 SL
Campers - Me, DW, 3 - DS (7, 5, 3), 2 large dogs
CHD Dad is offline   Reply With Quote
Old 07-23-2015, 11:44 AM   #13
Left Coast
I think the 'pain' would be getting the fittings the first time and the routing.
Old 07-23-2015, 05:05 PM   #14
WolfWhistle's Avatar
The flanges that are "bolted" together along with circular seals and a flat plastic blade makes up the blade valve. The hardest part for me was pulling pipes / flanges apart to get the seals and blade in gracefully. I reused the flanges since the are the same. PVC cement had ran into the valve at the factory making it more challenging.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 07-27-2015, 08:14 AM   #15
Taranwanderer's Avatar
I had the same issue with my rig...practically had to lie on the ground to get to the gray valve. I went with electric actuators. You can read the whole install, with some pics, here:
Replacment sewer drain valves
2015 XLR Hyperlite 30HFS5 (mods being performed regularly)
2009 Salem LA 292fkds (gone)
Nights- ('12)23 ('13)23 ('14)15 ('15)31 ('16)27 ('17) 20
2016 Ford Fusion Titanium (gulping gas again, camping support vehicle)
2014 Harley Davidson FLHX (XLR cargo)
2011 Ram 2500 CC 4X4 CTD, B&W Companion (toy hauler hauler)
Taranwanderer is offline   Reply With Quote
tank, valve
