Old 07-21-2015, 01:19 PM   #1
Angry Getting to the dump tank valves
Yes, I saw them when shopping. I saw them again when picking it up from the dealer. I even used them once at the dealer to try it and thought "it shouldnt be too bad". Wrong!
What FR engineer designed the stupid black and gray water valves to be Under the slide and about 2 FEET back from the edge and put the black valve BEHIND the second gray line?!?!?! Have they have been in a camper or used one before?
27HFS for reference but searching I saw the same complaints on others. What I havent found is if anyone has come up with a solution. I am 6'2" with some long arms and it was still a huge pain to get to that black valve. My wife would have had to been flat on her back and slid under to get to it.
Most of our camping is at State Parks with no full hookups so I figured it wouldnt be too bad at dump time. I cant imagine how fun that would be at a full hookup site with the slide all the way out!!
Any fixes or just learn to live with it?
'15 XLR 27HFS
'15 Nissan NVP 3500 SL
Campers - Me, DW, 3 - DS (7, 5, 3), 2 large dogs
CHD Dad is offline   Reply With Quote
Old 07-21-2015, 06:12 PM   #2
WolfWhistle's Avatar
If you search "what did you do to your XLR today" you will see what I did. Put a cable remote dump valve on the black. Moved the gray valve back. I can get to all three valves from one place and don't gave to strain. The valves are made by Alterra.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 07-21-2015, 07:03 PM   #3
2014 XLR 27HFS
Yep, I put a cable pull on the black and have the parts to do the greys. maybe next time out.
ID:	83645   Click image for larger version
ID:	83646   Click image for larger version
ID:	83647   Click image for larger version
Dave & Audrey
dave961 is offline   Reply With Quote
Old 07-21-2015, 07:19 PM   #4
Georgia Frog Rally 2018
aceinspp's Avatar
Some trailerr models done right others like yours done wrong. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 07-21-2015, 08:10 PM   #5
Left Coast
Only kitchen grey under slide on mine...others in front (of slide).
Old 07-22-2015, 10:55 AM   #6
InTheSticks's Avatar
Installed a Cable pull also on mine, which with the way the valve was glued on I had to mod the housing to get it on. Rarely use the front Grey tank so sometimes it doesn't get dumped..now if both grey tanks were plumbed together I would like that, extra shower capacity.
2013 F150 FX4 Crew Cab Lux Package
2013 Forest River XLR 27HFS
InTheSticks is offline   Reply With Quote
Old 07-22-2015, 10:58 AM   #7
Left Coast
Hacksaw and glue can make that happen!
Old 07-22-2015, 12:15 PM   #8
Dave961, I see you left the "RED" tab on yours...I thought your suppose to remove that after installation is done, no?
Old 07-22-2015, 01:59 PM   #9
Here's what my mod looks like. I never got around to painting the bracket. The cable operated valve is partially obscured by the light reflected off the white mat.
Old 07-22-2015, 02:21 PM   #10
If only Cousin Eddie had WW's setup.
breezyhillfarm is offline   Reply With Quote
tank, valve
