Old 04-19-2015, 08:54 PM   #1
Got a few things done this weekend...
Well, got a lot done this weekend. Got my roll up carpet trimmed and bound to go around my washer/dryer. The guys were nice enough to make me a door mat out of the cutout by binding it for free! Not bad for $25 total...
Painted up the genset exhaust with high temp header paint to keep it from rusting.
Added support to my sewage hose holder. The factory only screwed one side of it in due to it being wider than the frame it is screwed to. But, being plastic, I knew the leverage and vibration would have left it on the highway in no time. I used some scrap aluminum strips and some self tapping aluminum screws to make a brace over to the skirting of the trailer to keep it supported.
And the big job. I installed my MorRyde X-Factor cross braces. One standard one U021-003 and three of their brand new ones for the Correct Track locations. They were just developed this winter. Not sure if any others are out there. They aren't available through dealers yet, only direct. Part number UO21-015. These all should help with sway, strengthen the weak factory spring hangers, and prevent the tires from folding over when scrubbing in tight corners. Originally I was going to just have some 2"X2" square tubing welded in. It would have been cheaper but if ever there was a problem with anything in the underbelly like tanks or wiring, they would have to be cut out instead of being unbolted.
taken is offline   Reply With Quote
Old 04-23-2015, 08:33 AM   #2
I must be running out of projects. I sprayed my bright yellow 90 degree dog bone adapter in black Plastidip. Did my yellow cord end on my 50 amp cord and my 20 to 50 adapter while at it. Good $5.50 project. Nothing worse than bright yellow against nice sidewalls...
Old 04-23-2015, 07:20 PM   #3
Homebrew's Avatar
Looks great, where did you find a 50amp 90deg?
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 04-23-2015, 07:24 PM   #4
Homebrew's Avatar
Taken - you may want to take 10 inches off the generator exhaust.
The toll booths get a little tight and may hit the curb or orange cones.
I cut mine and when I use the generator I put it back on with a conduit coupling.
2014 Ram 3500 DRW
Old 04-23-2015, 07:41 PM   #5
The 90 degree can be had from two manufacturers. Camco and Marinco. I went with the Marinco as Camco can be crap at times. Got it on Amazon.
http://www.amazon.com/Marinco-1RPC50...+amp+90+degree
And the Camco one...
http://www.amazon.com/Camco-55572-Lo...+amp+90+degree
Im ok with the generator exhaust. It's only 5 inches. Same as my last rig. Never lost or "adjusted" it...
Old 04-25-2015, 07:45 AM   #6
Homebrew's Avatar
Thanks for the info!
On my 2nd trip we ran into road construction and one of the Orange cones did line up with the rest. The right side of the TH was the 6"-8" drop in grade.The exhaust pipe grabbed the cone and flipped it up and dented the skirt on the TH.😤
2014 Ram 3500 DRW
Old 04-25-2015, 08:03 AM   #7
Homebrew's Avatar
Correction - The cone did not line up with the others.
2014 Ram 3500 DRW
Old 04-25-2015, 08:48 AM   #8
That's a real stinker of a situation. Enough miles and anything can happen eh?
Old 04-25-2015, 09:46 AM   #9
darvinstone's Avatar
Rodney,
I'm liking your upgrades....what kind of silver paint/temperature rating did you use to paint your exhaust? Did you prime before applying the paint?
Thanks,
Stan
darvinstone is offline   Reply With Quote
Old 04-25-2015, 10:00 AM   #10
Stan,
It was leftover from another project and I used the last of it and tossed the can. Sorry. I think it was a VHT product that was rated to 2000. I see it on Amazon but in black only. Eastwood makes it in silver but more money. I'm sure you can find the silver VHT silver somewhere on the interwebber...
Old 04-25-2015, 11:12 AM   #11
Thanks, Rodney
Stan Stone
Lexington, NC
2016 XLR 375 AMP Thunderbolt
2014 F350 Lariat FX4 DRW (Fully Deleted)
Old 04-25-2015, 11:19 AM   #12
Oh, and I forgot to mention on the prep. No, I didn't prime. I scuffed the pipe with coarse steel wool then whiped it with a rag doused in laquer thinner to really clean it well. The thing to remember is you have to bake it on right after application. So, when done, start the generator and let it run for 20 minutes or so. I did the same on my last hauler and it lasted three years with some pretty decent use. The only place it ever failed was from rock strikes. I also did the hanger while I was at it so it wouldn't rust either.
Old 04-25-2015, 12:08 PM   #13
PS: don't forget to post up some pics of your rig Stan!!!
Old 04-25-2015, 07:24 PM   #14
My new rig....picked it up last Thursday from Jeff Couch RV Nation in OH.
Stan Stone
Lexington, NC
Old 04-25-2015, 07:28 PM   #15
Looking good Stan! The Intensity Pkg. is a winner for sure. We were back and fourth between it and paint for a while. It made the decision much harder...
PS: Would give anything if I could delete up here in MA and still pass out annual inspection...
Old 04-25-2015, 07:42 PM   #16
Thanks, Rodney...
I have my Progressive Industries hard wired surge protector, but haven't installed it yet. The wiring is very short and in a tight space for this 48 year old to climb into.
Ordered 6 new Goodyear G614's with metal valve stems to be installed on Monday.
Purchased the ventless washer dryer combo today.
Should have the X-Factor cross members orders this week.
I like your modifications so much Rodney, decided to just copy what your doing....as long as the money doesn't run out.
Stan Stone
Lexington, NC
Old 04-25-2015, 07:53 PM   #17
Thanks man! I'm honored! So, what's going in the garage besides the washer/dryer?
Old 04-25-2015, 07:58 PM   #18
Golf Cart in the garage. We are at Ocean Lakes Campground in Myrte Beach, SC. First trip and loving it, except for the rain today.
Stan Stone
Lexington, NC
Old 04-25-2015, 08:03 PM   #19
I'd give anything to be on our first trip today... Good deal. Maybe someday I'll run into you you out there....
Old 04-25-2015, 08:04 PM   #20
I do have a few small issues to resolve and Bob Elson with XLR have been very responsive to my emails. Bob took the time from his busy schedule to send me pictures of my unit going down the production line. XLR really cares about the customer and is first class.
Stan Stone
Lexington, NC
