Originally Posted by WolfWhistle
Steve have you looked at the Happijac user manual that came with the TH?
WW,
Yep, been reading ALL the manuals with adult beverages these past two nights...
The HappyJac manual only talks about moving the bed lowering stop position. The setup that came from the factory makes sense and would be perfect if I had the bed and the dinette. But since I only have the dinette and the bed mounting blocks are still installed in the tracks, along with the cutoff switch really limits the height the dinette can be raised.
I know I can unscrew the cutoff switch mounting plate, drill some new holes higher on the track, tap the holes and the remount the cutoff switch (at least this looked doable last night after a few adult beverages..
). Just curious if anyone has done this. OR if anyone recommends against doing it (for some reason...).
As always, really appreciate all the feedback. The knowledge on this forum is second to none...
