Old 03-27-2012, 11:08 PM   #1
Heat Pads Glue
On the bottom of the tanks are the heat pads. Two are coming loose. What have you used to glue them back up? Silicone?
GaryRudolph is offline   Reply With Quote
Old 03-28-2012, 06:36 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
3M #80 Spray-on Adhesive should be a good choice. It's compatible with plastics & rubber, heat resistant up to 200 degrees. Most importantly is getting the 2 surfaces clean before reattaching the heating pads.
3M Super 77 Multipurpose Spray Adhesive: spray aerosol adhesives, adhesive aerosols, aerosol spray adhesives product information, 3M U.S.:*3M
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 03-28-2012, 06:49 AM   #3
Herk7769's Avatar
UltraHeat - UltraHeat Webstore
You could also email them with your problem.
They might just send you what you need.
HAM CALLSIGN - KC3FFW
