Old 02-11-2016, 07:23 PM   #141
WolfWhistle's Avatar
Mr. NS, I had already run 12v into the pantry access for other things; so I tapped it there... ran inside pantry vertically.. added the remote there and exited the cabinet at a point that is low enough to be hidden from eye level but above the seal across the slide opening. The strip I bought was the warm white with adhesive backing. It provides a low level light that is nice. I use it all the time.
I ran a AWG 10 and an AWG 6 to that access panel fed by circuit breakers in the box for the genset, from the batteries.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 02-12-2016, 07:45 AM   #142
northstar1960's Avatar
thanks .I was looking at tapping in at the12v dinette switch and mounting to the back of the slide trim . so you mounted to the wall behind the slide trim ? I also ran 12v power to the pantry for an inverter in that location . i was looking for a way to fish the wires to the dinette switch and add a switch right next to that one . now i will re think my install . thanks again
northstar1960 is offline   Reply With Quote
Old 02-12-2016, 08:06 PM   #143
NS, yes, just above the seal but still below the top of the trim when closed.
Hyper Lite was sold
Old 04-13-2016, 03:01 PM   #144
PH,
How did your furnace turn out? Pics?
Thanks!
DennisTD is offline   Reply With Quote
Old 04-13-2016, 06:50 PM   #145
All you buddies are worried about you. Let us know you are okay... okay?
WW
Hyper Lite was sold
Old 04-13-2016, 07:31 PM   #146
He responded on another post, so he is around... Just busy...
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 04-19-2016, 02:48 AM   #147
Play Harder's Avatar
Ha busy dam I need a vacation! Heater in and huge huge difference I now have heat - even though it's still not optimal grrrr - installation company did a great job with install and reworking cabinets but grrr not separate the 4 ducts into there own outlets - easy fix and cheap if I can find time --- I have had it out in temps down in the low 40S and the new furnace easily keeps up and heats toyhauler now -
This was not an easy process 4plus months with me in the middle of XLR and WA repair shop - happy w outcome but would of been way - way easier and faster to do myself -
Thanks to Dianne at XLR for working with me to finally get this resolved..
Name:	ImageUploadedByForest River Forums1461052075.087948.jpg
ID:	105398Click image for larger version
Name:	ImageUploadedByForest River Forums1461052109.788496.jpg
Play Harder is offline   Reply With Quote
Old 04-19-2016, 08:34 AM   #148
Looks good PH!
Grrr indeed that they didn't get the ducts set up right. A modder's work is never done.
Diane is great, isn't she!
WW
Hyper Lite was sold
Old 04-19-2016, 09:45 AM   #149
at 40 since i don't heat the garage the set up i have with my mod works like a charm
hell even at 30 .
with all the added btu you have i wonder why they didn't had 4 more ducts . with out them i'll bet it's not long before the high limit starts to trip
Old 04-19-2016, 07:57 PM   #150
Attachment 105398Attachment 105399
Which furnace did you end up with?
Old 04-19-2016, 10:59 PM   #151
SFQ 35 - what they are currently installing In the 2016-17 model year -
North Star there is no comparison on how much more heat SFQ 35 put out compared to old even only Hooked to 2 vents ( which will be fixed soon ) turn furnace on and my toyhauler is now heated from 40s to 70 in less than 20 min the old would never get to 70 and would run 24/7 and this furnace is quieter go figure
Old 04-20-2016, 09:25 AM   #152
Glad it's working out. the 35 should have been in all from the get go . once you divide
the ducts into 4 it'll even be better . at least FR is learning, to bad it's at the expense of others . I'm satisfied with how mine heats the living area and runs very little . of course i never keep it above 68 and only 60 at night .
Old 04-20-2016, 09:42 AM   #153
If I find some cool weather I'll know how your mod works Mr. N, it seemed to work but haven't seen enough cold.First reservation today China Lake NAWR for a week this summer. That will let me get in some side trips. I want to boondock near Sedona and near Independence CA. Working on others.
WW
Hyper Lite was sold
Old 04-20-2016, 02:28 PM   #154
back in Colorado now below freezing at night no problems keeping up . i'm used to cooler weather even after spending the winter in Fl . but the furnace does not run much to keep me toasty
Old 04-20-2016, 03:37 PM   #155
You've also got 2" of foam belly pan
WW
Hyper Lite was sold
Old 04-20-2016, 04:54 PM   #156
WW
That's right keep forgetting the work i did that first week of ownership . the 2" foam board and reflective insulation over the tanks helps a lot
light, vent, xlr
