Old 02-11-2016, 06:23 PM   #141
WolfWhistle's Avatar
Mr. NS, I had already run 12v into the pantry access for other things; so I tapped it there... ran inside pantry vertically.. added the remote there and exited the cabinet at a point that is low enough to be hidden from eye level but above the seal across the slide opening. The strip I bought was the warm white with adhesive backing. It provides a low level light that is nice. I use it all the time.
I ran a AWG 10 and an AWG 6 to that access panel fed by circuit breakers in the box for the genset, from the batteries.
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 02-12-2016, 06:45 AM   #142
northstar1960's Avatar
thanks .I was looking at tapping in at the12v dinette switch and mounting to the back of the slide trim . so you mounted to the wall behind the slide trim ? I also ran 12v power to the pantry for an inverter in that location . i was looking for a way to fish the wires to the dinette switch and add a switch right next to that one . now i will re think my install . thanks again
northstar1960 is offline   Reply With Quote
Old 02-12-2016, 07:06 PM   #143
NS, yes, just above the seal but still below the top of the trim when closed.
Old 04-13-2016, 03:01 PM   #144
PH,
How did your furnace turn out? Pics?
Thanks!
DennisTD is offline   Reply With Quote
Old 04-13-2016, 06:50 PM   #145
All you buddies are worried about you. Let us know you are okay... okay?
WW
Old 04-13-2016, 07:31 PM   #146
He responded on another post, so he is around... Just busy...
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is online now   Reply With Quote
Old 04-19-2016, 02:48 AM   #147
Play Harder's Avatar
Ha busy dam I need a vacation! Heater in and huge huge difference I now have heat - even though it's still not optimal grrrr - installation company did a great job with install and reworking cabinets but grrr not separate the 4 ducts into there own outlets - easy fix and cheap if I can find time --- I have had it out in temps down in the low 40S and the new furnace easily keeps up and heats toyhauler now -
This was not an easy process 4plus months with me in the middle of XLR and WA repair shop - happy w outcome but would of been way - way easier and faster to do myself -
Thanks to Dianne at XLR for working with me to finally get this resolved..
Name:	ImageUploadedByForest River Forums1461052075.087948.jpg
ID:	105398Click image for larger version
Name:	ImageUploadedByForest River Forums1461052109.788496.jpg
Play Harder is offline   Reply With Quote
Old 04-19-2016, 08:34 AM   #148
Looks good PH!
Grrr indeed that they didn't get the ducts set up right. A modder's work is never done.
Diane is great, isn't she!
WW
Old 04-19-2016, 09:45 AM   #149
at 40 since i don't heat the garage the set up i have with my mod works like a charm
hell even at 30 .
with all the added btu you have i wonder why they didn't had 4 more ducts . with out them i'll bet it's not long before the high limit starts to trip
Old 04-19-2016, 07:57 PM   #150
Attachment 105398Attachment 105399
Which furnace did you end up with?
light, vent, xlr
