Old 04-19-2016, 10:59 PM   #151
Play Harder's Avatar
SFQ 35 - what they are currently installing In the 2016-17 model year -
North Star there is no comparison on how much more heat SFQ 35 put out compared to old even only Hooked to 2 vents ( which will be fixed soon ) turn furnace on and my toyhauler is now heated from 40s to 70 in less than 20 min the old would never get to 70 and would run 24/7 and this furnace is quieter go figure
Play Harder is offline   Reply With Quote
Old 04-20-2016, 09:25 AM   #152
northstar1960's Avatar
Glad it's working out. the 35 should have been in all from the get go . once you divide
the ducts into 4 it'll even be better . at least FR is learning, to bad it's at the expense of others . I'm satisfied with how mine heats the living area and runs very little . of course i never keep it above 68 and only 60 at night .
northstar1960 is offline   Reply With Quote
Old 04-20-2016, 09:42 AM   #153
WolfWhistle's Avatar
If I find some cool weather I'll know how your mod works Mr. N, it seemed to work but haven't seen enough cold.First reservation today China Lake NAWR for a week this summer. That will let me get in some side trips. I want to boondock near Sedona and near Independence CA. Working on others.
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 04-20-2016, 02:28 PM   #154
back in Colorado now below freezing at night no problems keeping up . i'm used to cooler weather even after spending the winter in Fl . but the furnace does not run much to keep me toasty
Old 04-20-2016, 03:37 PM   #155
You've also got 2" of foam belly pan
WW
Old 04-20-2016, 04:54 PM   #156
WW
That's right keep forgetting the work i did that first week of ownership . the 2" foam board and reflective insulation over the tanks helps a lot
light, vent, xlr
